PS C:\WINDOWS\system32> npm install -g edge-impulse-cli
npm WARN deprecated @zeit/dockerignore@0.0.5: "@zeit/dockerignore" is no longer maintained
npm WARN deprecated request-promise@4.2.4: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
npm ERR! code 1
npm ERR! path C:\Users\susha\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings
npm ERR! command failed
npm ERR! command C:\WINDOWS\system32\cmd.exe /d /s /c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
npm ERR! Building the projects in this solution one at a time. To enable parallel build, please add the "-m" switch.
npm ERR! serialport.cpp
npm ERR! serialport_win.cpp
npm ERR! win_delay_load_hook.cc
npm ERR! LINK : fatal error LNK1181: cannot open input file 'C:\\Users\\susha\\AppData\\Local\\node-gyp\\Cache\\18.13.0\\x64\\node.lib' [C:\Users\susha\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\build\bindings.vcxproj]
npm ERR! gyp info it worked if it ends with ok
npm ERR! gyp info using node-gyp@9.1.0
npm ERR! gyp info using node@18.13.0 | win32 | x64
npm ERR! gyp info find Python using Python version 3.10.4 found at "C:\Python310\python.exe"
npm ERR! gyp info find VS using VS2022 (17.4.33213.308) found at:
npm ERR! gyp info find VS "C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools"
npm ERR! gyp info find VS run with --verbose for detailed information
npm ERR! gyp info spawn C:\Python310\python.exe
npm ERR! gyp info spawn args [
npm ERR! gyp info spawn args 'C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\gyp\\gyp_main.py',
npm ERR! gyp info spawn args 'binding.gyp',
npm ERR! gyp info spawn args '-f',
npm ERR! gyp info spawn args 'msvs',
npm ERR! gyp info spawn args '-I',
npm ERR! gyp info spawn args 'C:\\Users\\susha\\AppData\\Roaming\\npm\\node_modules\\edge-impulse-cli\\node_modules\\@serialport\\bindings\\build\\config.gypi',
npm ERR! gyp info spawn args 'C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\addon.gypi',
npm ERR! gyp info spawn args 'C:\\Users\\susha\\AppData\\Local\\node-gyp\\Cache\\18.13.0\\include\\node\\common.gypi',
npm ERR! gyp info spawn args '-Dlibrary=shared_library',
npm ERR! gyp info spawn args '-Dvisibility=default',
npm ERR! gyp info spawn args '-Dnode_root_dir=C:\\Users\\susha\\AppData\\Local\\node-gyp\\Cache\\18.13.0',
npm ERR! gyp info spawn args '-Dnode_gyp_dir=C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp',
npm ERR! gyp info spawn args '-Dnode_lib_file=C:\\\\Users\\\\susha\\\\AppData\\\\Local\\\\node-gyp\\\\Cache\\\\18.13.0\\\\<(target_arch)\\\\node.lib',
npm ERR! gyp info spawn args '-Dmodule_root_dir=C:\\Users\\susha\\AppData\\Roaming\\npm\\node_modules\\edge-impulse-cli\\node_modules\\@serialport\\bindings',
npm ERR! gyp info spawn args '-Dnode_engine=v8',
npm ERR! gyp info spawn args '--depth=.',
npm ERR! gyp info spawn args '--no-parallel',
npm ERR! gyp info spawn args '--generator-output',
npm ERR! gyp info spawn args 'C:\\Users\\susha\\AppData\\Roaming\\npm\\node_modules\\edge-impulse-cli\\node_modules\\@serialport\\bindings\\build',
npm ERR! gyp info spawn args '-Goutput_dir=.'
npm ERR! gyp info spawn args ]
npm ERR! gyp info spawn C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\MSBuild\Current\Bin\MSBuild.exe
npm ERR! gyp info spawn args 'build/binding.sln',
npm ERR! gyp info spawn args '/clp:Verbosity=minimal',
npm ERR! gyp info spawn args '/nologo',
npm ERR! gyp info spawn args '/p:Configuration=Release;Platform=x64'
npm ERR! gyp ERR! build error
npm ERR! gyp ERR! stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\MSBuild\Current\Bin\MSBuild.exe` failed with exit code: 1
npm ERR! gyp ERR! stack at ChildProcess.onExit (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:201:23)
npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:513:28)
npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12)
npm ERR! gyp ERR! System Windows_NT 10.0.22000
npm ERR! gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
npm ERR! gyp ERR! cwd C:\Users\susha\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings
npm ERR! gyp ERR! node -v v18.13.0
npm ERR! gyp ERR! node-gyp -v v9.1.0
npm ERR! gyp ERR! not ok
Hello @sushantha,
It looks like this error: https://docs.edgeimpulse.com/docs/edge-impulse-cli/cli-installation#error-could-not-locate-the-bindings-file.-windows
Let me know if this solves your issue.
@sushantha The error code you displayed shows you are running node v18.13.0.
I just verified on Widows 10 that the EdgeImpulse CLI does not like node.js versions:
- v14.21.3
- v20.6.0
I could only get the EI CLI to install under node v18.7.1. (I did not try v18.13.0.)
What does node -v return?
