it seems the error is this:
ValueError: Shape (320, 320, 3) must have rank 4
I have no idea how to correct this. Please help.
The whole processing job is here:
Creating job… OK (ID: 796483)
Retraining Image…
Scheduling job in cluster…
Job started
Creating windows from 322 files…
[ 1/322] Creating windows from files…
[ 14/322] Creating windows from files…
[ 48/322] Creating windows from files…
[ 97/322] Creating windows from files…
[145/322] Creating windows from files…
[194/322] Creating windows from files…
[240/322] Creating windows from files…
[292/322] Creating windows from files…
[322/322] Creating windows from files…
Created 322 windows: rock: 157, tree trunk: 165
Creating features
[ 1/322] Creating features…
[ 30/322] Creating features…
[ 60/322] Creating features…
[ 91/322] Creating features…
[114/322] Creating features…
[145/322] Creating features…
[173/322] Creating features…
[204/322] Creating features…
[235/322] Creating features…
[266/322] Creating features…
[297/322] Creating features…
[322/322] Creating features…
Created features
Job started
Reducing dimensions for visualizations…
UMAP(a=None, angular_rp_forest=False, b=None,
force_approximation_algorithm=False, init=‘spectral’, learning_rate=1.0,
local_connectivity=1.0, low_memory=False, metric=‘euclidean’,
metric_kwds=None, min_dist=0.1, n_components=3, n_epochs=None,
n_neighbors=15, negative_sample_rate=5, output_metric=‘euclidean’,
output_metric_kwds=None, random_state=None, repulsion_strength=1.0,
set_op_mix_ratio=1.0, spread=1.0, target_metric=‘categorical’,
target_metric_kwds=None, target_n_neighbors=-1, target_weight=0.5,
transform_queue_size=4.0, transform_seed=42, unique=False, verbose=True)
Construct fuzzy simplicial set
Thu Apr 29 09:23:44 2021 Finding Nearest Neighbors
Thu Apr 29 09:23:46 2021 Finished Nearest Neighbor Search
Thu Apr 29 09:23:48 2021 Construct embedding
Still running…
completed 0 / 500 epochs
completed 50 / 500 epochs
completed 100 / 500 epochs
completed 150 / 500 epochs
completed 200 / 500 epochs
completed 250 / 500 epochs
completed 300 / 500 epochs
completed 350 / 500 epochs
completed 400 / 500 epochs
completed 450 / 500 epochs
Thu Apr 29 09:23:51 2021 Finished embedding
Reducing dimensions for visualizations OK
Retraining Image OK
Retraining Object detection…
Copying features from processing blocks…
Copying features from DSP block…
Still copying 4%…
Still copying 9%…
Still copying 14%…
Still copying 18%…
Still copying 22%…
Still copying 27%…
Still copying 32%…
Still copying 36%…
Still copying 41%…
Still copying 46%…
Still copying 50%…
Still copying 55%…
Still copying 60%…
Still copying 65%…
Still copying 70%…
Still copying 75%…
Still copying 79%…
Still copying 84%…
Still copying 89%…
Still copying 93%…
Still copying 98%…
Job started
Training model…
Training on 257 inputs, validating on 65 inputs
Building model and restoring weights for fine-tuning…
Finished restoring weights
Fine tuning…
Attached to job 796483…
File “/home/train.py”, line 240, in
main_function()
File “/home/train.py”, line 111, in main_function
X_train, X_test, Y_train, Y_test, len(X_train), classes, classes_values)
File “/home/train.py”, line 49, in train_model
train_dataset, validation_dataset)
File “./resources/libraries/ei_tensorflow/object_detection.py”, line 116, in train
val_loss += validation_fn(image_tensors, gt_boxes_list, gt_classes_list)
File “./resources/libraries/ei_tensorflow/object_detection.py”, line 185, in validation_function
prediction_dict = model.predict(concatted, shapes)
File “/usr/local/lib/python3.6/dist-packages/object_detection/meta_architectures/ssd_meta_arch.py”, line 570, in predict
feature_maps = self._feature_extractor(preprocessed_inputs)
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/keras/engine/base_layer.py”, line 1012, in call
outputs = call_fn(inputs, *args, **kwargs)
File “/usr/local/lib/python3.6/dist-packages/object_detection/meta_architectures/ssd_meta_arch.py”, line 251, in call
return self._extract_features(inputs)
File “/usr/local/lib/python3.6/dist-packages/object_detection/models/ssd_mobilenet_v2_fpn_keras_feature_extractor.py”, line 217, in _extract_features
33, preprocessed_inputs)
File “/usr/local/lib/python3.6/dist-packages/object_detection/utils/shape_utils.py”, line 280, in check_min_image_dim
image_height = static_shape.get_height(image_shape)
File “/usr/local/lib/python3.6/dist-packages/object_detection/utils/static_shape.py”, line 63, in get_height
tensor_shape.assert_has_rank(rank=4)
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/tensor_shape.py”, line 1014, in assert_has_rank
raise ValueError(“Shape %s must have rank %d” % (self, rank))
Job failed (see above)
