I was wondering if someone could help with an error I get when attempting to run my model on a Pi Zero for the first time
I’ve previously created my model using a Pi 3b, and ran classify.py successfully.
I’m setting up the PI Zero W for the first time, with a fresh install of Pi OS, all updates done, and the Python SDK installed using docs from the edge impulse website, here https://docs.edgeimpulse.com/docs/linux-python-sdk
Node.js isn’t installed on the PI Zero as Edge Impulse requires v12 which isn’t available on ARM6 / Pi Zero, but I don’t think it’s necessary to run the model
Here’s the error from the Pi Zero terminal window…
pi@pizerow:~/Documents $ python3 classify.py model.eim 11
File "classify.py", line 66, in <module>
main(sys.argv[1:])
File "classify.py", line 44, in main
model_info = runner.init()
File "/home/pi/.local/lib/python3.7/site-packages/edge_impulse_linux/audio.py", line 132, in init
model_info = super(AudioImpulseRunner, self).init()
File "/home/pi/.local/lib/python3.7/site-packages/edge_impulse_linux/runner.py", line 26, in init
raise Exception('Model file "' + self._model_path + '" is not executable')
Exception: Model file "/home/pi/Documents/model.eim" is not executable
Any help would be appreciated. Note I’ve tried changing the audio device to 1 instead of 11 in the arguments for classify.py but no change
UPDATE: I’ve altered the file permissions on model.eim to ‘anyone’ and now when I run classify,py again from the terminal, it just hangs and does nothing at all, not returning me to the command prompt?
I noted that during this ‘hang’ CPU utilisation = 1%, RAM = 50%
