I did collected droping sounds in format audio.wav then i aploaded in edge impulse and i started traning the dara and when i upoad the library in arduino ide and start real predection the system went all wrong i made 3 classes metal plastic and noise and noise inclued noise an silence please help !!
Helllo, @marzouguioussema !
Please try to fill as much detail as possible, this information will inform our tech team, and give the best time for resolution. Thanks!
[Provide the project ID]
- [Step 1]
- [Step 2]
- [Step 3]
- [ ] Always
- [ ] Sometimes
- [ ] Rarely
- Edge Impulse Version (Firmware): [e.g., 1.2.3]
