I am trying to run a run a simple motion detection ML module on my nRF52840 DK, and I am facing issues building it.
I followed the documentation and was able to build the wrapper example as it is.
Can you try to create a new API key in your project and test it again please?
To do so, go to Dashboard->Keys->create new API key
The API key should start with ei_
I will defer this issue to the core engineering team as I don’t have any idea on how to fix this
In the meantime, could you try to create a new project, import all your data and retrain your model and test again?
