Tried resetting the password, still having an issue.
Hi @SalmaSafe,
It looks like an IP connectivity issue. Are you behind a proxy by chance?
You can set the HTTPS_PROXY variable if that’s the case, see this topic for more details.
For additional debugging you can also run traceroute studio.edgeimpulse.com to check where the connectivity is failing.
