Hello there, recently I’ve been trying to upload a LeNet training block based on your example-custom-ml-block-pytorch repo. After fixing various bugs, I got the model uploaded to the platform and it produces exactly the same loss values as what I got when running the model locally, but the accuracy I got from EdgeImpulse was only 11% for 10 epochs. However, when I train the model locally , it gave me an accuracy of 98% with the same epoch number and learning rate.
In addition, I found that I got this during my training on EdgeImpulse:
Creating embeddings...
WARN: Creating embeddings failed: Default MaxPoolingOp only supports NHWC on device type CPU
[[node sequential/model/13/MaxPool
(defined at /app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/util/tf_stack.py:193)
]] [Op:__inference_predict_function_1175]
Errors may have originated from an input operation.
Input Source operations connected to node sequential/model/13/MaxPool:
In[0] sequential/model/12/Relu:
Operation defined at: (most recent call last)
>>> File "/home/profile.py", line 330, in <module>
>>> main_function()
My questions are listed below:
- Is the low accuracy on EdgeImpulse related to the warning and error above?
- How can I avoid this error? For convenience, I pasted my model code and the complete output from EdgeImpulse training console below. In the first line of forward() function, I have converted input from NWHC format to NCWH to make pytorch functions work. I think here is where the problem located.
- If it is not, how can I increase the accuracy? A comparison of 11% and 98% is really suprsing.
Looking forward to your help!
Model code
X_train = np.load(os.path.join(args.data_directory, 'X_split_train.npy'), mmap_mode='r')
Y_train = np.load(os.path.join(args.data_directory, 'Y_split_train.npy'))
X_test = np.load(os.path.join(args.data_directory, 'X_split_test.npy'), mmap_mode='r')
Y_test = np.load(os.path.join(args.data_directory, 'Y_split_test.npy'))
classes = Y_train.shape[1]
MODEL_INPUT_SHAPE = X_train.shape[1:]
# <<MODIFIED>>
class Model(Module):
def __init__(self):
super(Model, self).__init__()
self.conv1 = nn.Conv2d(1, 6, 5)
self.relu1 = nn.ReLU()
self.pool1 = nn.MaxPool2d(2)
self.conv2 = nn.Conv2d(6, 16, 5)
self.relu2 = nn.ReLU()
self.pool2 = nn.MaxPool2d(2)
self.fc1 = nn.Linear(256, 120)
self.relu3 = nn.ReLU()
self.fc2 = nn.Linear(120, 84)
self.relu4 = nn.ReLU()
self.fc3 = nn.Linear(84, 10)
self.relu5 = nn.ReLU()
def forward(self, x):
# convert NWHC to NCHW to make pytorch work
x = x.permute(0,3,1,2)
y = self.conv1(x)
y = self.relu1(y)
y = self.pool1(y)
y = self.conv2(y)
y = self.relu2(y)
y = self.pool2(y)
y = y.view(y.shape[0], -1)
y = self.fc1(y)
y = self.relu3(y)
y = self.fc2(y)
y = self.relu4(y)
y = self.fc3(y)
y = self.relu5(y)
return y
Complete output from EdgeImpulse training console:
Creating job... OK (ID: 7631702)
Scheduling job in cluster...
Job started
Container image pulled!
Job started
Splitting data into training and validation sets...
Job started
2023-04-03 22:28:15.852751: W tensorflow/stream_executor/platform/default/dso_loader.cc:64] Could not load dynamic library 'libcudart.so.11.0'; dlerror: libcudart.so.11.0: cannot open shared object file: No such file or directory
2023-04-03 22:28:15.852783: I tensorflow/stream_executor/cuda/cudart_stub.cc:29] Ignore above cudart dlerror if you do not have a GPU set up on your machine.
train.py:94: UserWarning: The given NumPy array is not writeable, and PyTorch does not support non-writeable tensors. This means you can write to the underlying (supposedly non-writeable) NumPy array using the tensor. You may want to copy the array to protect its data or make it writeable before converting it to a tensor. This type of warning will be suppressed for the rest of this program. (Triggered internally at ../torch/csrc/utils/tensor_numpy.cpp:189.)
X_train = torch.FloatTensor(X_train)
Attached to job 7631702...
Epoch 1: loss: 2.233
Epoch 2: loss: 0.887
Epoch 3: loss: 0.612
Epoch 4: loss: 0.564
Epoch 5: loss: 0.538
Epoch 6: loss: 0.524
Epoch 7: loss: 0.514
Epoch 8: loss: 0.502
Epoch 9: loss: 0.306
Epoch 10: loss: 0.285
Epoch 11: loss: 0.276
Epoch 12: loss: 0.270
Epoch 13: loss: 0.266
Epoch 14: loss: 0.262
Epoch 15: loss: 0.259
Test accuracy: 0.886333
Training network OK
INFO:pytorch2keras:Converter is called.
WARNING:pytorch2keras:Name policy isn't supported now.
WARNING:pytorch2keras:Custom shapes isn't supported now.
DEBUG:pytorch2keras:Input_names:
DEBUG:pytorch2keras:['input_0']
DEBUG:pytorch2keras:Output_names:
DEBUG:pytorch2keras:['output_0']
graph(%input_0 : Float(1, 1, 28, 28, strides=[784, 784, 28, 1], requires_grad=0, device=cpu),
%conv1.weight : Float(6, 1, 5, 5, strides=[25, 25, 5, 1], requires_grad=1, device=cpu),
%conv1.bias : Float(6, strides=[1], requires_grad=1, device=cpu),
%conv2.weight : Float(16, 6, 5, 5, strides=[150, 25, 5, 1], requires_grad=1, device=cpu),
%conv2.bias : Float(16, strides=[1], requires_grad=1, device=cpu),
%fc1.weight : Float(120, 256, strides=[256, 1], requires_grad=1, device=cpu),
%fc1.bias : Float(120, strides=[1], requires_grad=1, device=cpu),
%fc2.weight : Float(84, 120, strides=[120, 1], requires_grad=1, device=cpu),
%fc2.bias : Float(84, strides=[1], requires_grad=1, device=cpu),
%fc3.weight : Float(10, 84, strides=[84, 1], requires_grad=1, device=cpu),
%fc3.bias : Float(10, strides=[1], requires_grad=1, device=cpu)):
%11 : Float(1, 6, 24, 24, strides=[3456, 576, 24, 1], requires_grad=1, device=cpu) = onnx::Conv[dilations=[1, 1], group=1, kernel_shape=[5, 5], pads=[0, 0, 0, 0], strides=[1, 1]](%input_0, %conv1.weight, %conv1.bias) # /usr/local/lib/python3.8/dist-packages/torch/nn/modules/conv.py:442:0
%12 : Float(1, 6, 24, 24, strides=[3456, 576, 24, 1], requires_grad=1, device=cpu) = onnx::Relu(%11) # /usr/local/lib/python3.8/dist-packages/torch/nn/functional.py:1299:0
%13 : Float(1, 6, 12, 12, strides=[864, 144, 12, 1], requires_grad=1, device=cpu) = onnx::MaxPool[kernel_shape=[2, 2], pads=[0, 0, 0, 0], strides=[2, 2]](%12) # /usr/local/lib/python3.8/dist-packages/torch/nn/functional.py:719:0
%14 : Float(1, 16, 8, 8, strides=[1024, 64, 8, 1], requires_grad=1, device=cpu) = onnx::Conv[dilations=[1, 1], group=1, kernel_shape=[5, 5], pads=[0, 0, 0, 0], strides=[1, 1]](%13, %conv2.weight, %conv2.bias) # /usr/local/lib/python3.8/dist-packages/torch/nn/modules/conv.py:442:0
%15 : Float(1, 16, 8, 8, strides=[1024, 64, 8, 1], requires_grad=1, device=cpu) = onnx::Relu(%14) # /usr/local/lib/python3.8/dist-packages/torch/nn/functional.py:1299:0
%16 : Float(1, 16, 4, 4, strides=[256, 16, 4, 1], requires_grad=1, device=cpu) = onnx::MaxPool[kernel_shape=[2, 2], pads=[0, 0, 0, 0], strides=[2, 2]](%15) # /usr/local/lib/python3.8/dist-packages/torch/nn/functional.py:719:0
%17 : Long(requires_grad=0, device=cpu) = onnx::Constant[value={1}]() # train.py:77:0
%18 : Long(requires_grad=0, device=cpu) = onnx::Constant[value={-1}]()
%19 : Long(1, strides=[1], device=cpu) = onnx::Unsqueeze[axes=[0]](%17)
%20 : Long(1, strides=[1], device=cpu) = onnx::Unsqueeze[axes=[0]](%18)
%21 : Long(2, strides=[1], device=cpu) = onnx::Concat[axis=0](%19, %20)
%22 : Float(1, 256, strides=[256, 1], requires_grad=1, device=cpu) = onnx::Reshape(%16, %21) # train.py:77:0
%23 : Float(1, 120, strides=[120, 1], requires_grad=1, device=cpu) = onnx::Gemm[alpha=1., beta=1., transB=1](%22, %fc1.weight, %fc1.bias) # /usr/local/lib/python3.8/dist-packages/torch/nn/functional.py:1848:0
%24 : Float(1, 120, strides=[120, 1], requires_grad=1, device=cpu) = onnx::Relu(%23) # /usr/local/lib/python3.8/dist-packages/torch/nn/functional.py:1299:0
%25 : Float(1, 84, strides=[84, 1], requires_grad=1, device=cpu) = onnx::Gemm[alpha=1., beta=1., transB=1](%24, %fc2.weight, %fc2.bias) # /usr/local/lib/python3.8/dist-packages/torch/nn/functional.py:1848:0
%26 : Float(1, 84, strides=[84, 1], requires_grad=1, device=cpu) = onnx::Relu(%25) # /usr/local/lib/python3.8/dist-packages/torch/nn/functional.py:1299:0
%27 : Float(1, 10, strides=[10, 1], requires_grad=1, device=cpu) = onnx::Gemm[alpha=1., beta=1., transB=1](%26, %fc3.weight, %fc3.bias) # /usr/local/lib/python3.8/dist-packages/torch/nn/functional.py:1848:0
%output_0 : Float(1, 10, strides=[10, 1], requires_grad=1, device=cpu) = onnx::Relu(%27) # /usr/local/lib/python3.8/dist-packages/torch/nn/functional.py:1299:0
return (%output_0)
INFO:onnx2keras:Converter is called.
DEBUG:onnx2keras:List input shapes:
DEBUG:onnx2keras:[(1, 28, 28)]
DEBUG:onnx2keras:List inputs:
DEBUG:onnx2keras:Input 0 -> input_0.
DEBUG:onnx2keras:List outputs:
DEBUG:onnx2keras:Output 0 -> output_0.
DEBUG:onnx2keras:Gathering weights to dictionary.
DEBUG:onnx2keras:Found weight conv1.weight with shape (6, 1, 5, 5).
DEBUG:onnx2keras:...
DEBUG:onnx2keras:Check if all inputs are available:
DEBUG:onnx2keras:Check input 0 (name 27).
DEBUG:onnx2keras:... found all, continue
DEBUG:onnx2keras:Output TF Layer -> KerasTensor(type_spec=TensorSpec(shape=(None, 10), dtype=tf.float32, name=None), name='output_0/Relu:0', description="created by layer 'output_0'")
Saving saved model...
2023-04-03 22:42:50.550396: W tensorflow/python/util/util.cc:368] Sets are not currently considered sequences, but this may change in the future, so consider avoiding using them.
Saving saved model OK
Converting TensorFlow Lite float32 model...
2023-04-03 22:42:52.651163: W tensorflow/compiler/mlir/lite/python/tf_tfl_flatbuffer_helpers.cc:363] Ignored output_format.
2023-04-03 22:42:52.651197: W tensorflow/compiler/mlir/lite/python/tf_tfl_flatbuffer_helpers.cc:366] Ignored drop_control_dependency.
2023-04-03 22:42:52.652091: I tensorflow/cc/saved_model/reader.cc:43] Reading SavedModel from: /tmp/tmpkcs0pxcj
2023-04-03 22:42:52.654839: I tensorflow/cc/saved_model/reader.cc:107] Reading meta graph with tags { serve }
2023-04-03 22:42:52.654871: I tensorflow/cc/saved_model/reader.cc:148] Reading SavedModel debug info (if present) from: /tmp/tmpkcs0pxcj
2023-04-03 22:42:52.664761: I tensorflow/cc/saved_model/loader.cc:210] Restoring SavedModel bundle.
2023-04-03 22:42:52.715991: I tensorflow/cc/saved_model/loader.cc:194] Running initialization op on SavedModel bundle at path: /tmp/tmpkcs0pxcj
2023-04-03 22:42:52.730687: I tensorflow/cc/saved_model/loader.cc:283] SavedModel load for tags { serve }; Status: success: OK. Took 78599 microseconds.
2023-04-03 22:42:52.752737: I tensorflow/compiler/mlir/tensorflow/utils/dump_mlir_util.cc:237] disabling MLIR crash reproducer, set env var `MLIR_CRASH_REPRODUCER_DIRECTORY` to enable.
Estimated count of arithmetic ops: 0.572 M ops, equivalently 0.286 M MACs
2023-04-03 22:42:52.797172: I tensorflow/compiler/mlir/lite/flatbuffer_export.cc:1962] Estimated count of arithmetic ops: 0.572 M ops, equivalently 0.286 M MACs
Converting TensorFlow Lite float32 model OK
Converting TensorFlow Lite int8 model...
2023-04-03 22:42:53.983976: W tensorflow/compiler/mlir/lite/python/tf_tfl_flatbuffer_helpers.cc:363] Ignored output_format.
2023-04-03 22:42:53.984007: W tensorflow/compiler/mlir/lite/python/tf_tfl_flatbuffer_helpers.cc:366] Ignored drop_control_dependency.
2023-04-03 22:42:53.984233: I tensorflow/cc/saved_model/reader.cc:43] Reading SavedModel from: /tmp/tmpqygecbwg
2023-04-03 22:42:53.986391: I tensorflow/cc/saved_model/reader.cc:107] Reading meta graph with tags { serve }
2023-04-03 22:42:53.986423: I tensorflow/cc/saved_model/reader.cc:148] Reading SavedModel debug info (if present) from: /tmp/tmpqygecbwg
2023-04-03 22:42:53.998176: I tensorflow/cc/saved_model/loader.cc:210] Restoring SavedModel bundle.
2023-04-03 22:42:54.024644: I tensorflow/cc/saved_model/loader.cc:194] Running initialization op on SavedModel bundle at path: /tmp/tmpqygecbwg
2023-04-03 22:42:54.037518: I tensorflow/cc/saved_model/loader.cc:283] SavedModel load for tags { serve }; Status: success: OK. Took 53286 microseconds.
2023-04-03 22:42:54.102720: I tensorflow/compiler/mlir/lite/flatbuffer_export.cc:1962] Estimated count of arithmetic ops: 0.572 M ops, equivalently 0.286 M MACs
fully_quantize: 0, inference_type: 6, input_inference_type: 9, output_inference_type: 9
2023-04-03 22:43:01.912418: I tensorflow/compiler/mlir/lite/flatbuffer_export.cc:1962] Estimated count of arithmetic ops: 0.572 M ops, equivalently 0.286 M MACs
Converting TensorFlow Lite int8 model OK
Profiling model...
Job started
Loading data for profiling...
Loading data for profiling OK
>>> main_function()
>>> File "/home/profile.py", line 140, in main_function
>>> ei_tensorflow.embeddings.create_embeddings(
>>> File "/app/./resources/libraries/ei_tensorflow/embeddings.py", line 36, in create_embeddings
>>> X_pred = pred_from_savedmodel(model, SHAPE, rows, x_file)
>>> File "/app/./resources/libraries/ei_tensorflow/embeddings.py", line 70, in pred_from_savedmodel
>>> embeddings_len = model.predict(X_0).shape[1]
>>> File "/app/keras/.venv/lib/python3.8/site-packages/keras/utils/traceback_utils.py", line 64, in error_handler
>>> return fn(*args, **kwargs)
>>> File "/app/keras/.venv/lib/python3.8/site-packages/keras/engine/training.py", line 1789, in predict
>>> tmp_batch_outputs = self.predict_function(iterator)
>>> File "/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/util/traceback_utils.py", line 150, in error_handler
>>> File "/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/eager/def_function.py", line 910, in __call__
>>> result = self._call(*args, **kwds)
>>> File "/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/eager/def_function.py", line 958, in _call
>>> self._initialize(args, kwds, add_initializers_to=initializers)
>>> File "/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/eager/def_function.py", line 780, in _initialize
>>> self._stateful_fn._get_concrete_function_internal_garbage_collected( # pylint: disable=protected-access
>>> File "/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/eager/function.py", line 3157, in _get_concrete_function_internal_garbage_collected
>>> graph_function, _ = self._maybe_define_function(args, kwargs)
>>> File "/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/eager/function.py", line 3557, in _maybe_define_function
>>> graph_function = self._create_graph_function(args, kwargs)
>>> File "/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/eager/function.py", line 3392, in _create_graph_function
>>> func_graph_module.func_graph_from_py_func(
>>> File "/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/framework/func_graph.py", line 1143, in func_graph_from_py_func
>>> func_outputs = python_func(*func_args, **func_kwargs)
>>> File "/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/eager/def_function.py", line 672, in wrapped_fn
>>> out = weak_wrapped_fn().__wrapped__(*args, **kwds)
>>> File "/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/framework/func_graph.py", line 1118, in autograph_handler
>>> return autograph.converted_call(
>>> File "/app/keras/.venv/lib/python3.8/site-packages/keras/engine/training.py", line 1621, in predict_function
>>> return step_function(self, iterator)
>>> File "/app/keras/.venv/lib/python3.8/site-packages/keras/engine/training.py", line 1611, in step_function
>>> outputs = model.distribute_strategy.run(run_step, args=(data,))
>>> File "/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/distribute/distribute_lib.py", line 1316, in run
>>> return self._extended.call_for_each_replica(fn, args=args, kwargs=kwargs)
>>> File "/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/distribute/distribute_lib.py", line 2892, in call_for_each_replica
>>> return self._call_for_each_replica(fn, args, kwargs)
>>> File "/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/distribute/distribute_lib.py", line 3695, in _call_for_each_replica
>>> File "/app/keras/.venv/lib/python3.8/site-packages/keras/engine/training.py", line 1604, in run_step
>>> outputs = model.predict_step(data)
>>> File "/app/keras/.venv/lib/python3.8/site-packages/keras/engine/training.py", line 1572, in predict_step
>>> return self(x, training=False)
>>> File "/app/keras/.venv/lib/python3.8/site-packages/keras/engine/base_layer.py", line 1083, in __call__
>>> outputs = call_fn(inputs, *args, **kwargs)
>>> File "/app/keras/.venv/lib/python3.8/site-packages/keras/utils/traceback_utils.py", line 92, in error_handler
>>> File "/app/keras/.venv/lib/python3.8/site-packages/keras/engine/sequential.py", line 373, in call
>>> return super(Sequential, self).call(inputs, training=training, mask=mask)
>>> File "/app/keras/.venv/lib/python3.8/site-packages/keras/engine/functional.py", line 451, in call
>>> return self._run_internal_graph(
>>> File "/app/keras/.venv/lib/python3.8/site-packages/keras/engine/functional.py", line 589, in _run_internal_graph
>>> outputs = node.layer(*args, **kwargs)
>>> File "/app/keras/.venv/lib/python3.8/site-packages/keras/layers/pooling.py", line 357, in call
>>> outputs = self.pool_function(
>>> File "/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/util/dispatch.py", line 1096, in op_dispatch_handler
>>> return dispatch_target(*args, **kwargs)
>>> File "/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/ops/nn_ops.py", line 4865, in max_pool
>>> return gen_nn_ops.max_pool(
>>> File "/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/ops/gen_nn_ops.py", line 5387, in max_pool
>>> _, _, _op, _outputs = _op_def_library._apply_op_helper(
>>> File "/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/framework/op_def_library.py", line 744, in _apply_op_helper
>>> op = g._create_op_internal(op_type_name, inputs, dtypes=None,
>>> File "/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/framework/func_graph.py", line 689, in _create_op_internal
>>> return super(FuncGraph, self)._create_op_internal( # pylint: disable=protected-access
>>> File "/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/framework/ops.py", line 3697, in _create_op_internal
>>> ret = Operation(
>>> File "/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/framework/ops.py", line 2101, in __init__
>>> self._traceback = tf_stack.extract_stack_for_node(self._c_op)
>>> File "/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/util/tf_stack.py", line 193, in extract_stack_for_node
>>> return _tf_stack.extract_stack_for_node(
Calculating performance metrics...
Profiling float32 model...
Profiling int8 model...
Profiling 54% done
Model training complete
Job completed
