Good morning, I have a project of a standalone box using python, but my code is accusing the following error
import requests
import base64
from edgeimpulse_api import Configuration, ApiClient, ProjectsApi
Configurações de acesso ao Edge Impulse
API_KEY = ‘ei_XXXX’
PROJECT_ID = ‘208326’
HMAC_KEY = ‘f3eeXXXX’
Settings
host = “https://studio.edgeimpulse.com/v1”
api_key = “ei_8b2XXXX”
Create a client object that can connect to our project
config = Configuration(host=host, api_key={“ApiKeyAuthentication”: api_key})
client = ApiClient(config)
Get info about the project
projects = ProjectsApi(client)
project_list = projects.list_projects()
print(project_list.projects[0])
Função para fazer a detecção de objetos no Edge Impulse
def detect_objects(image_path):
with open(image_path, ‘rb’) as image_file:
image_data = image_file.read()
image_base64 = base64.b64encode(image_data).decode(‘utf-8’)
headers = {
‘Content-Type’: ‘application/json’,
‘x-api-key’: API_KEY,
‘x-imp-project-id’: PROJECT_ID,
‘x-imp-hmac’: HMAC_KEY
payload = {
‘image’: image_base64
response = requests.post(‘https://ingestion.edgeimpulse.com/api/infer’, headers=headers, json=payload)
if response.status_code == 200:
return response.json()
else:
print(‘Falha na detecção de objetos:’, response.text)
return None
Caminho da imagem para detecção de objetos
imagem_path = ‘/home/anderson/Downloads/20230424_090022.jpg’
Fazer a detecção de objetos
resultados_objetos = detect_objects(imagem_path)
Error: /bin/python /home/anderson/Desktop/smartcashier.py
id=210040 name=‘smart_cashier_FOMO (Created by Samuel Alexander)’ description=‘This is your Edge Impulse project. From here you acquire new training data, design impulses and train models.’ created=datetime.datetime(2023, 4, 12, 11, 55, 59, 773000, tzinfo=datetime.timezone.utc) owner=‘Victor Hugo Silva Corsi’ last_accessed=datetime.datetime(2023, 4, 26, 11, 10, 3, 592000, tzinfo=datetime.timezone.utc) logo=None owner_user_id=None owner_organization_id=27072 owner_avatar=None owner_is_developer_profile=True collaborators=[ProjectCollaborator(id=106734, username=‘vicorsi’, name=‘Victor Hugo Silva Corsi’, photo=‘’, created=datetime.datetime(2023, 4, 12, 11, 55, 59, 773000, tzinfo=datetime.timezone.utc), last_seen=None, staff_info=StaffInfo(is_staff=False, has_sudo_rights=False, company_name=None), pending=False, last_tos_acceptance_date=None, job_title=None, is_owner=True)] labeling_method=‘object_detection’ metadata={} data_explorer_screenshot=None is_enterprise_project=False whitelabel_id=None tags=[] category=‘Object detection’ license=None tier=‘free’ has_public_version=False
Error
Cannot POST /api/infer
Project ID: 208326
I have a project of a standalone box using python, but my code is accusing the following error, i need end this in 5 days, im using raspberry pi 4
Hi @vicorsi
Welcome to the forum!
What guide are you following? Trying to follow this but it seems like there is some confusion on the difference between ingesting data to your project, and running local inferencing? (Please clarify if i am wrong.)
Please see either of the following guides for the action you wish to perform here:
Ingestion (adding data to your project):
Inferencing (running the impulse or model locally):
Best Regards
