I had downloaded source code from below path
but getting error when i execute make -j
Hello @prashant.s,
It seems that you are not running the make -j command in the build-gnu/ directory.
If you cannot compile it your GNU toolchain, can you try with Docker please?
Did you initialize CMake?
$ mkdir build-gnu
$ cd build-gnu
$ cmake -DCMAKE_TOOLCHAIN_FILE=toolchain.gnu.cmake ..
Hello @prashant.s,
Can you try with Docker please?
It will surely solve a lot of problems.
link for procedure to be followed…for installing and building using docker…
It is in the link you shared
You need to copy and paste the command exactly: docker build -t himax-build -f Dockerfile .
You’re still missing the “.” at the end of the command to specify the current directory where the Dockerfile is located.
