Using MacOS 10.15.6
Used brew to install node.
Used brew to install arduino-cli
$ node -v returns v14.10.1
$ arduino-cli board list returns
Port Type Board Name FQBN Core
/dev/cu.Bluetooth-Incoming-Port Serial Port Unknown
/dev/cu.RonaldsiPad-WirelessiAP Serial Port Unknown
/dev/cu.usbmodem14201 Serial Port (USB) Arduino Nano 33 BLE arduino-beta:mbed:nano33ble arduino-beta:mbed
My problem is when I run:
$ npm install -g edge-impulse-cli
/usr/local/bin/edge-impulse-uploader -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/uploader.js
/usr/local/bin/edge-impulse-data-forwarder -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/data-forwarder.js
/usr/local/bin/edge-impulse-daemon -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/daemon.js
/usr/local/bin/edge-impulse-run-impulse -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/run-impulse.js
/usr/local/bin/eta-flash-tool -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/eta-flash-tool/flashtool.js
@serialport/bindings@8.0.8 install /usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings
prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
prebuild-install WARN install No prebuilt binaries found (target=14.10.1 runtime=node arch=x64 libc= platform=darwin)
No receipt for ‘com.apple.pkg.CLTools_Executables’ found at ‘/’.
No receipt for ‘com.apple.pkg.DeveloperToolsCLILeo’ found at ‘/’.
No receipt for ‘com.apple.pkg.DeveloperToolsCLI’ found at ‘/’.
gyp: No Xcode or CLT version detected!
gyp ERR! configure error
gyp ERR! stack Error: gyp failed with exit code: 1
gyp ERR! stack at ChildProcess.onCpExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
gyp ERR! stack at ChildProcess.emit (events.js:314:20)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
gyp ERR! System Darwin 19.6.0
gyp ERR! command “/usr/local/Cellar/node/14.10.1/bin/node” “/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “rebuild”
gyp ERR! cwd /usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings
gyp ERR! node -v v14.10.1
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
npm WARN tsargs@1.4.0 requires a peer of typescript@^3.1.6 but none is installed. You must install peer dependencies yourself.
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! @serialport/bindings@8.0.8 install: prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the @serialport/bindings@8.0.8 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! /Users/ronald/.npm/_logs/2020-09-16T17_24_02_027Z-debug.log
Ronalds-MBP:~ ronald$ edge-impulse-daemon
-bash: edge-impulse-daemon: command not found
I would appreciate any suggestions.
Thanks for reporting back!
