Generate features
Question/Issue: I have a problem: getImageChannelCount called, but DSP block is neither of type “image”, “custom” or “organization”
**Project ID:**6662265
Hi @Elaine-Silva,
That project ID does not look correct. Could you check the URL of your project or try copying it again from the dashboard? It’s likely a number less than ~193000
Could you provide some context around the error message you are seeing? What were you trying to do, and where did you see the error message? Also, was that the entire message?
Oi, eu acho que peguei o Id errado.
**ID do projeto:**191529
Eu estou na parte de tratar os dados, ao ir na parte de generate features ele apresenta esse erro:
Creating job… OK (ID: 6810696)
Scheduling job in cluster…
Job started
Job failed (see above)
Hi @Elaine-Silva,
You are using a “Raw Data” block with image data. You need to use an “Image” processing block instead, as shown in this screenshot.
