I get this error when I try to generate features,
*Creating windows from 1 files...*
*Job started*
*Scheduling job in cluster...*
*Attached to job 1994967...*
*[1/1] Creating windows from files...*
*Traceback (most recent call last):*
* File "/app/input-block-preprocessing/downsample.py", line 86, in <module>*
* window = sn.resample_poly(window, target_freq, sample_freq, axis=ds_axis)*
* File "/usr/local/lib/python3.7/dist-packages/scipy/signal/signaltools.py", line 3089, in resample_poly*
* h = firwin(2 * half_len + 1, f_c, window=window)*
* File "/usr/local/lib/python3.7/dist-packages/scipy/signal/fir_filter_design.py", line 457, in firwin*
* m = np.arange(0, numtaps) - alpha*
*ValueError: Maximum allowed size exceeded*
*Error windowing Downsample error code was not 0, but was 1*
*Downsample error code was not 0, but was 1*
*Application exited with code 1 (Error)*
*Job failed (see above)*
I tried adjusting window size, window increase and frequency with no luck.
Can you please help me
