Hi all,
Can I connect a gas sensor with Arduino nano sense and train in a edge impulse?
Hello @sunim,
Yes you can. You would need to adapt the edge-impulse-data-forwarder script on your arduino to forward your samples to EI studio. More info here: https://docs.edgeimpulse.com/docs/cli-data-forwarder
Just print the values from your sensor in the serial console at a chosen frequency. How do you read the values from your gas sensor? Is it an analog device such as the MQ135? If so, I would do something like that:
#define FREQUENCY_HZ 50
#define INTERVAL_MS (1000 / (FREQUENCY_HZ + 1))
const int gasPin = A0;
void setup() {
Serial.begin(115200);
Serial.println("Started");
void loop() {
float gasValue;
if (millis() > last_interval_ms + INTERVAL_MS) {
last_interval_ms = millis();
gasValue = analogRead(gasPin);
//Add some conversion or calibration here if needed
Serial.println(gasValue);
Then for the inference, you’ll need to store the gas sensor values in a features buffer. You can find some more info here: https://docs.edgeimpulse.com/docs/running-your-impulse-locally-1#input-to-the-run_classifier-function
