Frequency only increases
Greetings,
My original data consisted of a set consists of 400, one minute long recordings sampled at 48000 Hz
i am failing to store this frequency . What could be the problem? Am i having the wrong frequency?
why is it saying frquency should be greater than 0 when it is already greater than 0, why only increments of 1?
Hi @Irene,
How did you import your dataset? It looks like the sampling frequency is very low.
When importing as json, the interval_ms needs to be set (https://docs.edgeimpulse.com/reference/data-acquisition-format). In your case it should be: 0.020833.
Hi @Irene For some reason we rejected frequencies between 0 and 1Hz. Fixing this in the next patch release (either tomorrow or Monday).
But why are you saying 48000 Hz and then selecting a freq <1 Hz? Are you sure you have uploaded the data correctly?
