FOMO Returning 'null' for Class Name
Project ID: 173213, a FOMO model that counts screws in an image. There is only 1 class in the Model called screw.
The quantized (int8) Model memory usage seems typical (nice and small) for a FOMO Model:
  • RAM USAGE = 244.0K
  • FLASH USAGE = 74.6K
Upon running the static_buffer.ino with an output of:
run_classifier returned: 0
Predictions (DSP: 10 ms., Classification: 1239 ms., Anomaly: 0 ms.):
[0.00000]
(null): 0.00000
  • the classification time of 1239 ms seems very long for running on a Sony Spresense
  • not to mention the model returns null and not the class name of screw
When running the float Model:
  • RAM USAGE = 898.8K
  • FLASH USAGE = 96.6K
the output is:
Edge Impulse Inferencing Demo
Predictions (DSP: 11 ms., Classification: 3136 ms., Anomaly: 0 ms.):
[0.00000]
(null): 0.00000
  • the memory requirements estimation for the FOMO model alone seems excessive
  • the classification time of over 3 seconds seems so very long for running on a Sony Spresense
  • again the model returns null and not the class name of screw
Questions
  • Why are the Models returning null for the Class type with a prediction value of 0.00000000000000000000000000000000000000000000000000000000000?
Hello @MMarcial,
You’re working on the Sony Spresense with the Arduino Sketch correct?
So the Cortex-M4F is indeed pretty slow even with FOMO but it should not give you (null): 0.00000.
What are the results when you use the pre-compiled firmware?
The short answer is the Edge Impulse version of static_buffer.ino that I used is in no way capable of handling a FOMO model. I am not sure what version I used because there seems to be no versioning on the EI Example Arduino files.
I created a version called static_buffer_fomo_too.ino that handles Image Classification models as well as FOMO (Image Segmentation) models. The code is here.
The long answer…
@louis The pre-compiled firmware worked since the issue is in the Arduino file.
The line
prints
(null): 0.00000
…as is expected when one is running a FOMO model since
result.classification[ix].label does not exist.
What one wants are the properties off of
result.bounding_boxes
and not properties off of
@MMarcial,
Thanks, I’ll check with the Embedded Team if they can modify the static_buffer.ino default example to support FOMO.
We should have something like what we have in the camera sketches:
    // Run the classifier
    if (err != EI_IMPULSE_OK) {
        return;
    // print the predictions
        if (bb.value == 0) {
            continue;
        ei_printf("    %s (", bb.label);
        ei_printf_float(bb.value);
        ei_printf(") [ x: %u, y: %u, width: %u, height: %u ]\n", bb.x, bb.y, bb.width, bb.height);
    if (!bb_found) {
        ei_printf("    No objects found\n");
#else
        ei_printf("    %s: ", result.classification[ix].label);
        ei_printf_float(result.classification[ix].value);
        ei_printf("\n");
    ei_printf("    anomaly score: ");
    ei_printf_float(result.anomaly);
    ei_printf("\n");
#endif
#endif
Thanks for figuring this out!
Hello @MMarcial,
We have a PR in progress, the static_buffer example will be updated soon so it can “support” FOMO without any modifications.
