FOMO not working for two different objects in a single frame
Will the FOMO model detect more than one different object in a frame? I have trained the model to detect two different objects (a banana and a cup). After training and retraining the model, when I tried to classify in real-time, with both objects in the frame at the same time, it wasn’t able to detect anything. Is this something I can fix, if so how?
[Provide the project ID]
609080
Detecting two objects in the same frame using FOMO model using iPhone camera during live classification
Summary:
When two different objects were shown in the frame at the same time, the model wasn’t able to detect anything
Expected Results:
Originally, I expected for both objects to be detected in the frame
Actual Results:
When both objects were shown together, none of them were able to be detected
  • Always
  • Platform: [iPhone camera]
Hi @rakshana
You should be able to track two different classes with FOMO without issue, this looks like a poor dataset / class imbalance issue. Try to follow our model improvement guide: Increasing model performance | Edge Impulse Documentation
Thanks, Eoin for the suggestions! I will try these methods in my project.
Hello @rakshana,
I just had a quick look at your project and my suggestion would be to:
  • add more images to your dataset
  • also add images with both the banana and the cup in the same frame
