Question/Issue: Why is the build failing?
Project ID: 113205
Context/Use case:Login - Edge Impulse
The build output shows:
Library Portenta_Audio has been declared precompiled:
Precompiled library in “/root/.arduino15/packages/arduino/hardware/mbed_portenta/2.8.0/libraries/Portenta_Audio/src/cortex-m7/fpv5-d16-softfp” not found
Using precompiled library in /root/.arduino15/packages/arduino/hardware/mbed_portenta/2.8.0/libraries/Portenta_Audio/src/cortex-m7
Still building…
Still building…
Still building…
Still building…
Still building…
/tmp/arduino-sketch-69B153BD87785079E90CB38B66839D39/linker_script.ld:104 cannot move location counter backwards (from 00000000240d1f00 to 000000002407fc00)
Error during build: exit status 1
real 4m49.194s
user 4m36.846s
sys 2m57.084s
Job failed (see above)
