you do need to include the sampleids need to be present in y_true since they are required to join back to the ground truth x values…
here’s an example of using the API to get some of the required meta data to join things since the lookup from sampleid to the original X image filename isn’t immediate. this should all run in notebook, colab etc
hope it helps!
mat
# based on https://studio.edgeimpulse.com/studio/316474/dsp/image/3
PROJECT_ID = 316474
DSP_ID = 3
EI_USER = "your_user_name"
EI_PASSWORD = getpass.getpass()
setup API cookies
headers = {
'accept': "application/json",
'content-type': "application/json"
url = "https://studio.edgeimpulse.com/v1/api-login"
body = {
'username': EI_USER,
'password': EI_PASSWORD
response = requests.request('POST', url, headers=headers,
data=json.dumps(body))
cookies = dict(jwt=response.json()['token'])
fetch the assets available for download
url = f"https://studio.edgeimpulse.com/v1/api/{PROJECT_ID}/downloads"
response = requests.request('GET', url, headers=headers, cookies=cookies)
downloads = json.loads(response.content.decode())
downloads['downloads']
[{'name': 'Image training data',
'type': 'NPY file',
'size': '3 windows',
'link': '/v1/api/316474/dsp-data/3/x/training'},
{'name': 'Image training labels',
'type': 'JSON file',
'link': '/v1/api/316474/dsp-data/3/y/training'},
{'name': 'Object detection model',
'type': 'TensorFlow Lite (float32)',
'size': '83 KB',
'link': '/v1/api/316474/learn-data/5/model/tflite-float'},
'type': 'TensorFlow Lite (int8 quantized)',
'size': '55 KB',
'link': '/v1/api/316474/learn-data/5/model/tflite-int8'},
'type': 'TensorFlow SavedModel',
'size': '187 KB',
'link': '/v1/api/316474/learn-data/5/model/tflite-savedmodel'},
'type': 'Keras h5 model',
'size': '90 KB',
'link': '/v1/api/316474/learn-data/5/model/tflite-h5'}]
get x.npy
# get training data as a numpy array
SET = 'x/training'
url = f"https://studio.edgeimpulse.com/v1/api/{PROJECT_ID}/dsp-data/{DSP_ID}/{SET}"
print(url)
with open('foo', 'wb') as f:
f.write(response.content)
x = np.load('foo')
x.shape
https://studio.edgeimpulse.com/v1/api/316474/dsp-data/3/x/training
(3, 27648)
get y data, as json
# get y data as json
import json
SET = 'y/training'
y = json.loads(response.content.decode())
y
{'version': 1,
'samples': [{'sampleId': 713162941,
'boundingBoxes': [{'label': 1, 'x': 32, 'y': 52, 'w': 13, 'h': 12},
{'label': 1, 'x': 51, 'y': 52, 'w': 13, 'h': 12},
{'label': 1, 'x': 55, 'y': 33, 'w': 13, 'h': 13}]},
{'sampleId': 713162940,
'boundingBoxes': [{'label': 1, 'x': 22, 'y': 58, 'w': 13, 'h': 12}]},
{'sampleId': 713162939,
'boundingBoxes': [{'label': 1, 'x': 40, 'y': 31, 'w': 13, 'h': 13},
{'label': 1, 'x': 30, 'y': 54, 'w': 13, 'h': 12},
{'label': 1, 'x': 68, 'y': 55, 'w': 15, 'h': 14}]}]}
fetch corresponding sampleids via metadata
# fetch corresponding sample ids via metadata
url = f"https://studio.edgeimpulse.com/v1/api/{PROJECT_ID}/dsp/{DSP_ID}/metadata"
metadata = response.json()
sample_ids = [d['id'] for d in metadata['includedSamples']]
assert len(sample_ids) == x.shape[0]
map sampleids back to filenames
# map back from sample_ids to filenames
sample_id_to_filename = {}
for sample_id in sample_ids:
url = f"https://studio.edgeimpulse.com/v1/api/{PROJECT_ID}/raw-data/{sample_id}"
sample_orig_fname = response.json()['sample']['filename']
sample_id_to_filename[sample_id] = sample_orig_fname
{713162941: 'cubes.jpg.23im597e.ingestion-6797d84bf-dn6tb',
713162940: 'cubes.jpg.23ima5a3.ingestion-6797d84bf-mkqlt',
713162939: 'cubes.jpg.23imaso8.ingestion-6797d84bf-mkqlt'}
