Obeyda
November 15, 2022, 9:47pm
#1
Hello everyone,
I have been trying to get the nRF9160 DK connected to Edge Impulse Platform but it is not possible. i have been following this viedo Connecting nRF9160 DK to Edge Impulse - YouTube for connecting the Dk to the Platform.
after flashing the application and tyring to run this command edge-impulse-daemon
i am still getting this output
C:\Users\USER>edge-impulse-daemon
node:internal/modules/cjs/loader:998
throw err;
Error: Cannot find module ‘C:\Users\USER\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\daemon.js’
at Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
at Module._load (node:internal/modules/cjs/loader:841:27)
at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
at node:internal/main/run_main_module:23:47 {
code: ‘MODULE_NOT_FOUND’,
requireStack: []
Node.js v18.12.1
C:\Users\USER>
so what should i do to get the DK connected to Edge Impulse ??
i would be sp happy for your help.
Many thanks
Obaida
If daemon.js file is not there then you probably have not installed the Edge Impulse Command Line Interface (CLI) . CLI install instructions are here .
Obeyda
November 29, 2022, 5:59pm
#3
Hey,
first of all many thanks to your answer. unfortunately i am still not able to connect the DK to the Platform.
after installing the CLI that was the output :
then i did exactly like what was in this viedo Connecting nRF9160 DK to Edge Impulse - YouTube
and after flashing the board , that was the output :
after running the command edge-impulse-daemon that was the output :
after choosing the first COM like the video description that was the output:
and at the end there is no connection between the DK and the paltform.
would you please just tell me , what should i do anymore ??
all programmed have been installed but unfortunately i cant get any connection until now.
I would be super happy for any other informations.
Best Regards
Obaida
In Windows Device Manager is your nRF9160 listed under Ports (COM & LPT) as COM5?
louis
November 30, 2022, 9:42am
#5
So the CLI is now installed correctly!
Also, just a quick question, are you using the X-NUCLEO-IKS02A1 extension shield? It is mandatory to use this one to connect the board using edge impulse default firmware.
I remember I ordered the wrong one when I first tested it more than a year and a half ago and I ran into a similar issue.
Also this board is a bit capricious, see Nordic Semi nRF9160 DK - Edge Impulse Documentation .
Obeyda
November 30, 2022, 6:35pm
#6
Hey, actually you can find all ports here and i have no idea which port should i choose in this case ? would you please tell me !!
Obeyda
November 30, 2022, 6:47pm
#7
i think i have ordered the wrong one instead of [X-NUCLEO-IKS02A1] i ordered this one
[X-NUCLEO-IKS01A2] !!!
louis
December 1, 2022, 10:43am
#8
Arf, I did the same mistake
@louis How do they enumerate in Windows Device Manager ? @Obeyda ’s previous post shows:
JLink CDC UART Port (COM3)
JLink CDC UART Port (COM4)
JLink CDC UART Port (COM5)
I thought JLink was a JTAG debugger. Do the Nordic boards enumerate as JLinks as well?
If you do indeed have a JLink attached, then unplug it and see if the Nordic board enumerates in DevMan.
