edge-impulse-run-impulse --raw
After a lot of messages saying failed to connect… it connects eventually and then no messages. Last message was
[SER] Connected to /dev/ttyACM0
I think the firmware itself is not successfully installed. Because when i run the .sh file. The terminal shows commands like…
Nano 33 BLE Sense OK…
AND THEN IT CLOSES… IT SAYS NOTHING AFTERWARDS! It happens so fast that i even couldn’t see the terminal properly.
Can you try to use another USB cable?
Which OS are you using?
If last message was [SER] Connected to /dev/ttyACM0 when using the edge-impulse-run-impulse --raw command, can you try to type AT+RUNIMPULSE ending by a carriage return.
I managed to solve it by installing an older version of arduino cli…
the previous version was 0.23.x
I tried downloading 0.18.x
The board has been successfully flashed!
