Firmware-st-b-l475e-iot01a for STM32CubeIDE
did someone ported the edge impiulse firmware for the ST Board to CubeIDE already?
And would share it?
Greats
Peter
@AssKicker not that I’m aware of, but why would you need this? The C++ LIbrary exports and STM32Cube.AI exports should be enough to run the finished impulse using CubeIDE.
I want to compile your Board firmware (https://github.com/edgeimpulse/firmware-st-b-l475e-iot01a) in CubeIDE to reconfig the accelerometer.
@AssKicker if you import the application with Mbed CLI (see the README) you’ll have a BSP_B-L475E-IOT01 folder with the BSP for this target, and you can reconfig the accelerometer there (in firmware-st-b-l475e-iot01a/BSP_B-L475E-IOT01/Drivers/BSP/B-L475E-IOT01/stm32l475e_iot01_accelero.c).
ok, thanks for the fast help
i will try it :slight_smile:
I wouldn’t call it a full port, but I’ve got the keyword spotting demo to work in STM32CubeIDE. I put a couple of demos in this repo: https://github.com/ShawnHymel/ei-keyword-spotting
At the bottom of the README, I added some notes about what you need to do to get an Edge Impulse library to run in STM32CubeIDE.
Hope it helps!
I tried to create Library to STM32CubeIDE but it fails for some reason. Should this work and if it should, how can I find the generate error report to see what is the problem.
Unfortunately there is a bug with some models and Cube.AI - you can use the C++ export with Build C++ Library with STM32CubeIDE
Is there any guidance how to include created C++ Library to STM32CubeIDE project?
@ArtoK, yes follow the steps in Build C++ Library with STM32CubeIDE
