Firmware-silabs-xg24 cannot be successfully imported into simplicity studio 5
My environment windows 10
Simplicity studio 5
SDK: gecko_sdk_4.2.2
Toolchans: GNU ARM Toolchain (v10.3.2021.10) - 10.3.2021.10
(figure 1)
Refer to GitHub - edgeimpulse/firmware-silabs-xg24 this step,
Delete the ei-model link
(figure 2)
Click Force Regeneration
(figure 3)
build code gets the first error
(figure 4)
In C/C++ Build β†’ settings in properties, I added C:\Users\User\Downloads\firmware-silabs-xg24-main\ei-model to both GNU ARM C Compiler and GNU ARM C++ Compiler includes
(figure 5)
Currently fatal error: gatt_db.h: No such file or directory, how to deal with it?
(figure 6)
Please advise, thanks
Best Regards.
Rick.
figure 2
WeChat ζˆͺεœ–_20230425173521
figure 3
figure 4
figure 5
figure 6
@mateusz,
Do you have any idea?
@f81258 @louis
It is probably the incompatibility problem with the newest Simplicity Studio. The format of the SLCC component has changed, and we are in the progress of fixing that.
Mateusz
@mateusz
Which version do I need to change to be able to use it normally?
Best Regards.
Rick.
@f81258
I don’t know the exact version number, but probably the last release from 2022 should work. AFAIK Silabs introduced a new SLCC format in January 2023.
Best regards,
Mateusz
@mateusz
Thanks for your reply.
  1. Do you have any relevant files or download points?
  2. When will it be updated to support the latest version?
Best Regards.
Rick.
@mateusz
I can success run it.
thank.
Hello @f81258,
I am glad that you made it work, feel free to let me know if I can make some changes in the documentation to ease the process for other people.
