Hi, I’d cloned this repo https://github.com/edgeimpulse/firmware-nordic-thingy53 and attempt to build the firmware using nRF Connect SDK (v2.1.0) in VS code. There are some errors during the build process which I’m not able to trace/solve.
-- Found devicetree overlay: C:/nRF/myapps/EI_download1/boards/thingy53_nrf5340_cpuapp.overlay
node '/soc/peripheral@50000000/i2c@9000/vm3011@60' compatible 'vesper,vm3011' has unknown vendor prefix 'vesper'
-- Generated zephyr.dts: C:/nRF/myapps/EI_download1/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/nRF/myapps/EI_download1/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/nRF/myapps/EI_download1/build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/nRF/myapps/EI_download1/build/zephyr/dts.cmake
Parsing C:/nRF/myapps/EI_download1/Kconfig
C:/ncs/v2.1.0/zephyr/scripts/kconfig/kconfig.py: Dependency loop
I2C (defined at boards/shields\adafruit_2_8_tft_touch_v2\Kconfig.defconfig:16, boards/shields\amg88xx\Kconfig.defconfig:7, boards/shields\buydisplay_2_8_tft_touch_arduino\Kconfig.defconfig:13, boards/shields\buydisplay_3_5_tft_touch_arduino\Kconfig.defconfig:13, boards/shields\frdm_stbc_agm01\Kconfig.defconfig:7, boards/shields\lmp90100_evb\Kconfig.defconfig:28, boards/shields\ssd1306\Kconfig.defconfig:17, boards/shields\x_nucleo_53l0a1\Kconfig.defconfig:9, boards/shields\x_nucleo_eeprma2\Kconfig.defconfig:14, boards/shields\x_nucleo_iks01a2\Kconfig.defconfig:7, boards/shields\x_nucleo_iks01a3\Kconfig.defconfig:7, boards/shields\x_nucleo_iks02a1\Kconfig.defconfig:7, C:/ncs/v2.1.0/zephyr/boards/arm/thingy53_nrf5340/Kconfig.defconfig:89, drivers/i2c/Kconfig:9), with definition...
config I2C
bool
default y
depends on KSCAN && DISPLAY && (SHIELD_ADAFRUIT_2_8_TFT_TOUCH_V2 || SHIELD_ADAFRUIT_2_8_TFT_TOUCH_V2_NANO)
config I2C
bool
default y if SENSOR
depends on SHIELD_AMG88XX_EVAL_KIT
config I2C
bool
default y
depends on KSCAN && DISPLAY && SHIELD_BUYDISPLAY_2_8_TFT_TOUCH_ARDUINO
config I2C
bool
default y
depends on KSCAN && DISPLAY && SHIELD_BUYDISPLAY_3_5_TFT_TOUCH_ARDUINO
config I2C
bool
default y if SENSOR
depends on SHIELD_FRDM_STBC_AGM01
config I2C
bool
default y
depends on EEPROM && SHIELD_LMP90100_EVB
config I2C
bool
default y
depends on (SHIELD_SSD1306_128X64 || SHIELD_SSD1306_128X32 || SHIELD_SH1106_128X64) && DISPLAY && (SHIELD_SSD1306_128X64 || SHIELD_SSD1306_128X64_SPI || SHIELD_SSD1306_128X32 || SHIELD_SH1106_128X64)
config I2C
bool
default y
depends on SHIELD_X_NUCLEO_53L0A1
config I2C
bool
default y
depends on EEPROM && SHIELD_X_NUCLEO_EEPRMA2
config I2C
bool
default y if SENSOR
depends on SHIELD_X_NUCLEO_IKS01A2
config I2C
bool
default y if SENSOR
depends on SHIELD_X_NUCLEO_IKS01A3
config I2C
bool
default y if SENSOR
depends on SHIELD_X_NUCLEO_IKS02A1
config I2C
bool
default y
depends on !TRUSTED_EXECUTION_SECURE && (BOARD_THINGY53_NRF5340_CPUAPP || BOARD_THINGY53_NRF5340_CPUAPP_NS)
menuconfig I2C
bool "I2C Drivers"
help
Enable I2C Driver Configuration
(select-related dependencies: (ADT7420 && DT_HAS_ADI_ADT7420_ENABLED && SENSOR) || (AK8975 && DT_HAS_ASAHI_KASEI_AK8975_ENABLED && SENSOR) || (AMG88XX && DT_HAS_PANASONIC_AMG88XX_ENABLED && SENSOR) || (AMS_IAQ_CORE && DT_HAS_AMS_IAQCORE_ENABLED && SENSOR) || (APDS9960 && DT_HAS_AVAGO_APDS9960_ENABLED && SENSOR) || (BMA280 && DT_HAS_BOSCH_BMA280_ENABLED && SENSOR) || (BMC150_MAGN && DT_HAS_BOSCH_BMC150_MAGN_ENABLED && SENSOR) || (BMG160 && DT_HAS_BOSCH_BMG160_ENABLED && SENSOR) || (BMI270 && DT_HAS_BOSCH_BMI270_ENABLED && SENSOR) || (BMM150 && DT_HAS_BOSCH_BMM150_ENABLED && SENSOR) || (BQ274XX && DT_HAS_TI_BQ274XX_ENABLED && SENSOR) || (CCS811 && DT_HAS_AMS_CCS811_ENABLED && SENSOR) || (DPS310 && DT_HAS_INFINEON_DPS310_ENABLED && SENSOR) || (ENS210 && DT_HAS_AMS_ENS210_ENABLED && SENSOR) || (FDC2X1X && DT_HAS_TI_FDC2X1X_ENABLED && NEWLIB_LIBC && SENSOR) || (FXAS21002 && DT_HAS_NXP_FXAS21002_ENABLED && SENSOR) || (FXOS8700 && DT_HAS_NXP_FXOS8700_ENABLED && SENSOR) || (TI_HDC && DT_HAS_TI_HDC_ENABLED && SENSOR) || (TI_HDC20XX && (DT_HAS_TI_HDC2010_ENABLED || DT_HAS_TI_HDC2021_ENABLED || DT_HAS_TI_HDC2022_ENABLED || DT_HAS_TI_HDC2080_ENABLED) && SENSOR) || (HMC5883L && DT_HAS_HONEYWELL_HMC5883L_ENABLED && SENSOR) || (HP206C && DT_HAS_HOPERF_HP206C_ENABLED && SENSOR) || (INA23X && (DT_HAS_TI_INA230_ENABLED || DT_HAS_TI_INA237_ENABLED) && SENSOR) || (ISL29035 && DT_HAS_ISIL_ISL29035_ENABLED && SENSOR) || (INA219 && DT_HAS_TI_INA219_ENABLED && SENSOR) || (LIS3MDL && DT_HAS_ST_LIS3MDL_MAGN_ENABLED && SENSOR) || (LM75 && DT_HAS_LM75_ENABLED && SENSOR) || (LM77 && DT_HAS_LM77_ENABLED && SENSOR) || (LPS22HB && DT_HAS_ST_LPS22HB_PRESS_ENABLED && SENSOR) || (LPS25HB && DT_HAS_ST_LPS25HB_PRESS_ENABLED && SENSOR) || (LSM303DLHC_MAGN && DT_HAS_ST_LSM303DLHC_MAGN_ENABLED && SENSOR) || (LSM6DS0 && DT_HAS_ST_LSM6DS0_ENABLED && SENSOR) || (LSM9DS0_GYRO && DT_HAS_ST_LSM9DS0_GYRO_ENABLED && SENSOR) || (LSM9DS0_MFD && DT_HAS_ST_LSM9DS0_MFD_ENABLED && SENSOR) || (MAX17055 && DT_HAS_MAXIM_MAX17055_ENABLED && SENSOR) || (MAX17262 && DT_HAS_MAXIM_MAX17262_ENABLED && SENSOR) || (MAX30101 && DT_HAS_MAXIM_MAX30101_ENABLED && SENSOR) || (MAX31875 && DT_HAS_MAXIM_MAX31875_ENABLED && SENSOR) || (MAX44009 && DT_HAS_MAXIM_MAX44009_ENABLED && SENSOR) || (MCP9808 && DT_HAS_MICROCHIP_MCP9808_ENABLED && SENSOR) || (MPR && DT_HAS_HONEYWELL_MPR_ENABLED && SENSOR) || (MPU6050 && DT_HAS_INVENSENSE_MPU6050_ENABLED && SENSOR) || (MPU9250 && DT_HAS_INVENSENSE_MPU9250_ENABLED && SENSOR) || (MS5837 && DT_HAS_MEAS_MS5837_ENABLED && SENSOR) || (OPT3001 && DT_HAS_TI_OPT3001_ENABLED && SENSOR) || (SBS_GAUGE && DT_HAS_SBS_SBS_GAUGE_ENABLED && SENSOR) || (SGP40 && DT_HAS_SENSIRION_SGP40_ENABLED && SENSOR) || (SHTCX && DT_HAS_SENSIRION_SHTCX_ENABLED && SENSOR) || (SHT3XD && DT_HAS_SENSIRION_SHT3XD_ENABLED && SENSOR) || (SHT4X && DT_HAS_SENSIRION_SHT4X_ENABLED && SENSOR) || (SI7006 && DT_HAS_SILABS_SI7006_ENABLED && SENSOR) || (SI7055 && DT_HAS_SILABS_SI7055_ENABLED && SENSOR) || (SI7060 && DT_HAS_SILABS_SI7060_ENABLED && SENSOR) || (SI7210 && DT_HAS_SILABS_SI7210_ENABLED && SENSOR) || (STTS751 && DT_HAS_ST_STTS751_ENABLED && SENSOR) || (SX9500 && DT_HAS_SEMTECH_SX9500_ENABLED && SENSOR) || (TH02 && DT_HAS_HOPERF_TH02_ENABLED && SENSOR) || (TMP007 && DT_HAS_TI_TMP007_ENABLED && SENSOR) || (TMP108 && DT_HAS_TI_TMP108_ENABLED && SENSOR) || (TMP112 && DT_HAS_TI_TMP112_ENABLED && SENSOR) || (TMP116 && DT_HAS_TI_TMP116_ENABLED && SENSOR) || (VCNL4040 && DT_HAS_VISHAY_VCNL4040_ENABLED && SENSOR) || (VL53L0X && DT_HAS_ST_VL53L0X_ENABLED && SENSOR) || (ITDS && DT_HAS_WE_WSEN_ITDS_ENABLED && SENSOR) || (COUNTER_MICROCHIP_MCP7940N && DT_HAS_MICROCHIP_MCP7940N_ENABLED && COUNTER))
...depends on SHT4X (defined at drivers/sensor/sht4x/Kconfig:6), with definition...
config SHT4X
bool "SHT4x Temperature and Humidity Sensor"
default y
select I2C
depends on DT_HAS_SENSIRION_SHT4X_ENABLED && SENSOR
help
Enable driver for SHT4x temperature and humidity sensors.
...depends on SENSOR (defined at boards/shields\x_nucleo_53l0a1\Kconfig.defconfig:12, C:/ncs/v2.1.0/nrf\drivers\sensor/Kconfig:7, drivers/sensor/Kconfig:6), with definition...
config SENSOR
bool
default y
menuconfig SENSOR
bool "Sensor Drivers"
help
Include sensor drivers in config
menuconfig SENSOR
help
Include sensor drivers in system config
(select-related dependencies: (BT_BAS && BT_CONN && BT_RPC_STACK) || (BT_BAS && BT_CONN && BT_CONN && BT_HCI_HOST && BT_RPC_STACK) || (NRF_802154_SL_OPENSOURCE && NRF_802154_TEMPERATURE_UPDATE && <choice NRF_802154_SL_TYPE>) || (VM3011 && I2C) || (NRF_802154_SL && NRF_802154_TEMPERATURE_UPDATE && !NRF_802154_SOURCE_HAL_NORDIC && <choice NRF_802154_SL_TYPE>) || (NRF_802154_SL_OPENSOURCE && NRF_802154_TEMPERATURE_UPDATE && <choice NRF_802154_SL_TYPE>) || (CLOCK_CONTROL_NRF_USES_TEMP_SENSOR && HAS_HW_NRF_TEMP && CLOCK_CONTROL_NRF_DRIVER_CALIBRATION && CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION && CLOCK_CONTROL_NRF && CLOCK_CONTROL) || (BT_BAS && BT_CONN && BT_CONN && BT_HCI_HOST && BT_HCI && BT))
...depends on VM3011 (defined at C:/nRF/myapps/EI_download1/drivers/vm3011/Kconfig.vm3011:4), with definition...
menuconfig VM3011
bool "VM3011 dmic"
select NRFX_PDM
select SENSOR
depends on I2C
help
Enable driver for VM3011 Digital MEMS Microphone.
...depends again on I2C (defined at boards/shields\adafruit_2_8_tft_touch_v2\Kconfig.defconfig:16, boards/shields\amg88xx\Kconfig.defconfig:7, boards/shields\buydisplay_2_8_tft_touch_arduino\Kconfig.defconfig:13, boards/shields\buydisplay_3_5_tft_touch_arduino\Kconfig.defconfig:13, boards/shields\frdm_stbc_agm01\Kconfig.defconfig:7, boards/shields\lmp90100_evb\Kconfig.defconfig:28, boards/shields\ssd1306\Kconfig.defconfig:17, boards/shields\x_nucleo_53l0a1\Kconfig.defconfig:9, boards/shields\x_nucleo_eeprma2\Kconfig.defconfig:14, boards/shields\x_nucleo_iks01a2\Kconfig.defconfig:7, boards/shields\x_nucleo_iks01a3\Kconfig.defconfig:7, boards/shields\x_nucleo_iks02a1\Kconfig.defconfig:7, C:/ncs/v2.1.0/zephyr/boards/arm/thingy53_nrf5340/Kconfig.defconfig:89, drivers/i2c/Kconfig:9)
CMake Error at C:/ncs/v2.1.0/zephyr/cmake/modules/kconfig.cmake:293 (message):
command failed with return code: 1
Call Stack (most recent call first):
C:/ncs/v2.1.0/zephyr/cmake/modules/zephyr_default.cmake:121 (include)
C:/ncs/v2.1.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
C:/ncs/v2.1.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
CMakeLists.txt:15 (find_package)
-- Configuring incomplete, errors occurred!
FATAL ERROR: command exited with status 1: 'c:\ncs\toolchains\v2.1.0\opt\bin\cmake.EXE' '-DWEST_PYTHON=c:\ncs\toolchains\v2.1.0\opt\bin\python.exe' '-Bc:\nRF\myapps\EI_download1\build' -GNinja -DBOARD=thingy53_nrf5340_cpuapp -DNCS_TOOLCHAIN_VERSION:STRING=NONE -DCONF_FILE:STRING=c:/nRF/myapps/EI_download1/boards/thingy53_nrf5340_cpuapp.conf -DBOARD_ROOT:STRING=c:/nRF/myapps/EI_download1 '-Sc:\nRF\myapps\EI_download1'
