Finding problem in object detection
Question/Issue: Finding problem in object detection.
Project ID: 195095
I am working on the Car detection modal and I am finding this error while seeing the result on the serial Monitor.
Edge Impulse Inferencing Demo
Inferencing settings:
Image resolution: 96x96
Frame size: 9216
No. of classes: 1
Starting inferencing in 2 seconds…
Taking photo…
Failed to run impulse (-6)
Taking photo…
Hi @Tarun.ece ,
It looks like you don’t have enough memory on the device to run the impulse. Which device are you targeting?
See this as well…
Hi
i am using Arduino Nano 33 BLE Sense
@Tarun.ece,
BLE Sense is very limited in RAM. Shrinking input images to 64x64 and using grayscale should work though. Also make sure to select a small FOMO model.
