Since Edge is starting to work on Vision programming with the Arduino PortentaH7 and PortentaH7Lite, can we consider the audience.
This is a Pro Auduino but it is essentially a board for advanced Makers and Firms that don’t want to hire: Mechatronic, Electrical or Computer Science Engineers. The above Engineers could probably do the same as the $104 USD Portenta with $47-$63 USD Vision Shield(s) at a fraction of the cost using the $10 ESP32, PCB board design like https://jlcpcb.com/ and https://easyeda.com/ and lots of inexpensive components.
For the rest of us there is the Portenta.
Can Edge Impulse put some planning into how to make the Vision code as simple as possible? First let’s get it working, but then can we look at other ways to make it easier.
Here is my version of the Tensorflow “Hello Sine Wave” example that has been made easier by putting most of the confusing code in the #include "model.h" and #include "rocksetta.h" repository folder here. Note: all my Portenta examples can be installed with the Arduino IDE searchable library type “Portenta” and look for portenta-pro-community-solutions
* b01_makerML_hello_world.ino
* simplifying TensorflowLite Micro Machine Learning for all makers
* By Jeremy Ellis
* Twitter @rocksetta
* Website https://rocksetta.com
* created Aug 20th, 2020
* Github https://github.com/hpssjellis/my-examples-for-the-arduino-portentaH7/tree/master/m09-Tensoflow
* Hashtags
* #TensorflowLiteMicro
* #TensorflowLiteForArduino
* #TinyMY
* #MakerML
#include "Arduino.h"
#include <TensorFlowLite.h>
#include "model.h"
/*================= Start Maker Area ======================================*/
int myCounter = 0;
int myLed = LED_BUILTIN; //or 7 or 5 or LED_BUILTIN or LEDB
void setup() {
Serial.begin(9600);
pinMode(myLed, OUTPUT);
modelSetup(model_tflite); // name of the model in the tab model.h
void loop() {
myCounter +=1;
if (myCounter >= 360){
myCounter = 0;
float x_val = myCounter * 3.14/180; // degrees to radians
float y_val = sin(x_val);
// This uses your model to make a prediction
float predicted = modelPredict(x_val);
Serial.println("sin(" +String(x_val)+ ") = " + String(y_val) + "\t predicted: " + String(predicted) );
// y=1 LED is fully on. The LED's brightness can range from 0-255.
int brightness = (int)(127.5f * (predicted+1));
#if defined (CORE_CM7) || defined (CORE_CM4)
if (brightness <= 128){
digitalWrite(myLed, HIGH); // means off
} else {
digitalWrite(myLed, LOW); // means on
#else
analogWrite(myLed, brightness); // not on Porttenta
#endif
delay(3); // slows the process down a bit to see the sine wave
/*================= End Maker Area ======================================*/
The above example is a much more Arduino friendly, Machine Learning Model version of the TensorflowLite example hello_world.ino that you can find here here
Vision Machine Learning Models are a fair bit more complex than using Tensorflow to make a sine wave, but the point of this request is that we try to make the Edge Impulse Portenta Vision examples as user friendly as possible.
I am willing to help test, debug and make suggestions etc if needed.
Good luck.
