Feature Request: Allow the connected device PortentaH7 with MKRIMU to run acceleration data collection.
From a coding point of view everything should be the exact same as the Nano33BleSense motion models except using the MKRIMU.h library instead of the Arduino_LSM9DS1.h library.
//#include <Arduino_LSM9DS1.h>
#include <MKRIMU.h>
You can see from the following image that a PortentaH7 connected with the MKRIMU does not show the option to collect motion data.
Note: Even if the Vision Shield is not connected it still gives the microphone or Camera options, not sure if there is a way to test if the vision or MKRIMU shields are connected, but would probably be good from a coding point of view. A pop-up suggesting to connect the required shield, would be a good idea.
