Hi,i got problem when i run this command
APP_AUDIO=1 CC=aarch64-linux-gnu-gcc CXX=aarch64-linux-gnu-g++ TARGET_LINUX_AARCH64=1 USE_FULL_TFLITE=1 make -j.
And
sudo apt install libasound2
doesn’t work.
And
doesn’t work.
What’s the issue with the install command? Does it install the package but fails or does it fail to install the package.
If apt isn’t installed try this:
sudo apt-get install libasound2
        @rjames
Hi rjames,
I have install the package successfully.I have tried sudo apt-get install libasound2,but doesn’t work.
Can you try
sudo apt install libasound2-dev
        @rjames Hi rjames ,
Maybe this error has been solved after restarting my ubuntu.But there is a new error.This is the same as Error in C++ SDK - #7 by rjames. What can i do for this bug to solve it. Do this bug will till for a long time?
Thanks ~
See the other thread. I’ve posted a work-around.
