I’m in the tinyML summit. Seems I can’t install edge-impulse-cli.
I’m on macOS big sur 11.2.3
Here’s the log
(base) Dads15in2018MacbookPro:dev hding$ npm install -g edge-impulse-cli
npm WARN deprecated @zeit/dockerignore@0.0.5: "@zeit/dockerignore" is no longer maintained
/usr/local/bin/edge-impulse-daemon -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/daemon.js
/usr/local/bin/edge-impulse-blocks -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/blocks.js
/usr/local/bin/eta-flash-tool -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/eta-flash-tool/flashtool.js
/usr/local/bin/edge-impulse-uploader -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/uploader.js
/usr/local/bin/himax-flash-tool -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/himax-flash-tool/flashtool.js
/usr/local/bin/edge-impulse-framebuffer2jpg -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/framebuffer-to-jpg.js
/usr/local/bin/edge-impulse-run-impulse -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/run-impulse.js
/usr/local/bin/edge-impulse-data-forwarder -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/data-forwarder.js
> @serialport/bindings@8.0.8 install /usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings
> prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
prebuild-install WARN install No prebuilt binaries found (target=14.16.0 runtime=node arch=x64 libc= platform=darwin)
CXX(target) Release/obj.target/bindings/src/serialport.o
clang: error: unknown argument: '-m'
make: *** [Release/obj.target/bindings/src/serialport.o] Error 1
gyp ERR! build error
gyp ERR! stack Error: `make` failed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
gyp ERR! stack at ChildProcess.emit (events.js:315:20)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:277:12)
gyp ERR! System Darwin 20.3.0
gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings
gyp ERR! node -v v14.16.0
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! @serialport/bindings@8.0.8 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the @serialport/bindings@8.0.8 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! /Users/hding/.npm/_logs/2021-03-22T17_43_08_787Z-debug.log
