I am trying to train an object detection dataset that can localise three different classes of objects within an image. I have been successful in uploading my image dataset, creating an impulse and generating features, but when i start to train MobileNetV2 SSD FPN-Lite 320x320 I am met with some errors which I do not understand how to correct.
I will attach a copy of my training output, I am sorry for including what is probably redundant information by attaching my whole training output… but i dont want to risk not including the correct info.
Could some one please be able to help me with this?
Kind regards
Training Output**************
Creating job… OK (ID: 677579)
Copying features from processing blocks…
Copying features from DSP block…
Still copying 5%…
Still copying 9%…
Still copying 14%…
Still copying 19%…
Still copying 23%…
Still copying 28%…
Still copying 33%…
Still copying 37%…
Still copying 42%…
Still copying 46%…
Still copying 51%…
Still copying 55%…
Still copying 60%…
Still copying 64%…
Still copying 69%…
Still copying 73%…
Still copying 78%…
Still copying 82%…
Still copying 87%…
Still copying 91%…
Still copying 96%…
Scheduling job in cluster…
Job started
Training model…
Training on 180 inputs, validating on 46 inputs
Building model and restoring weights for fine-tuning…
Finished restoring weights
Fine tuning…
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/eager/context.py”, line 2113, in execution_mode
yield
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/data/ops/iterator_ops.py”, line 733, in _next_internal
output_shapes=self._flat_output_shapes)
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/ops/gen_dataset_ops.py”, line 2579, in iterator_get_next
_ops.raise_from_not_ok_status(e, name)
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/ops.py”, line 6862, in raise_from_not_ok_status
six.raise_from(core._status_to_exception(e.code, message), None)
File “”, line 3, in raise_from
tensorflow.python.framework.errors_impl.UnknownError: IndexError: invalid index to scalar variable.
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/ops/script_ops.py”, line 247, in call
return func(device, token, args)
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/ops/script_ops.py”, line 135, in call
ret = self._func(*args)
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/autograph/impl/api.py”, line 620, in wrapper
return func(*args, **kwargs)
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/data/ops/dataset_ops.py”, line 960, in generator_py_func
values = next(generator_state.get_iterator(iterator_id.numpy()))
File “./resources/libraries/ei_tensorflow/training.py”, line 91, in gen
raw_boxes = Y_values[ix][‘boundingBoxes’]
[[{{node EagerPyFunc}}]] [Op:IteratorGetNext]
File “/home/train.py”, line 240, in
main_function()
File “/home/train.py”, line 111, in main_function
X_train, X_test, Y_train, Y_test, len(X_train), classes, classes_values)
File “/home/train.py”, line 49, in train_model
train_dataset, validation_dataset)
File “./resources/libraries/ei_tensorflow/object_detection.py”, line 101, in train
for batch in train_dataset:
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/data/ops/iterator_ops.py”, line 747, in next
return self._next_internal()
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/data/ops/iterator_ops.py”, line 739, in _next_internal
return structure.from_compatible_tensor_list(self._element_spec, ret)
File “/usr/lib/python3.6/contextlib.py”, line 99, in exit
self.gen.throw(type, value, traceback)
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/eager/context.py”, line 2116, in execution_mode
executor_new.wait()
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/eager/executor.py”, line 69, in wait
pywrap_tfe.TFE_ExecutorWaitForAllPendingNodes(self._handle)
Job failed (see above)
