So I was trying to deploy my model back to my raspberry pi 4. When I run the command ‘edge-impulse-linux-runner’ it says ‘Failed to run impulse Error: Unsupported architecture “aarch64”’. I already tried to reinstall the OS. Please help me.
I would follow this tutorial. I am guessing node.js and npm are not fully setup or installed.
The only changes I had to make were:
- Use
node.jsversion 19 not 12. - Line
npm config set user root && sudo npm install edge-impulse-linux -g --unsafe-permwould not run so I skipped the 1st part and just ran:sudo npm install edge-impulse-linux -g --unsafe-perm
how to use node.js version 19 not 12?
For node.js version 12:
sudo apt update
curl -sL https://deb.nodesource.com/setup_12.x | sudo bash -
sudo apt install -y gcc g++ make build-essential nodejs sox gstreamer1.0-tools gstreamer1.0-plugins-good gstreamer1.0-plugins-base gstreamer1.0-plugins-base-apps
For node.js version 19:
sudo apt update
curl -sL https://deb.nodesource.com/setup_19.x | sudo bash -
bro it still does not work. the error still shows after running "edge-impulse-linux-runner’. please somebody help me.
When deploying are you selecting AARCH64?
greeting from taiwan! i actually have this problem too,i also install node.js ver19 and run * sudo npm install edge-impulse-linux -g --unsafe-perm again,but still says " Failed to run impulse Unsupported architecture “aarch64”, only armv7l or aarch64 supported for now ". now should i deploying another firmware like armv7?
for this problem i already resolve it. try to reinstall a raspberry os in 64 bit. thank you!
Hi all,
If you are running into the following error:
it likely means you are attempting to deploy a .eim Edge Impulse model file to a 32-bit operating system running on a 64-bit CPU. To check your hardware architecture and OS in Linux, please run the following commands:
uname -m
uname -a
getconf LONG_BIT
If you see something like this:
$ uname -m
aarch64
$ uname -a
Linux raspberrypi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
$ getconf LONG_BIT
32
it means that you are running 32-bit Linux on a 64-bit hardware system, which will not deploy or run Edge Impulse .eim files. Please download and reinstall a 64-bit version of your operating system to run .eim files.
This was recently made somewhat confusing for Raspberry Pi because their website now gives you the 32-bit version of Raspberry Pi OS by default. When you download the Raspberry Pi OS, please select the 64-bit version:
