Failed to run classifier on ESP32-S3
Hi there,
I tried to deploy impulses on the ESP32-S3-WROOM-1 using arudino IDE and I get the same error every time.
Starting inferencing in 2 seconds…
Sampling…
ERR: Would write outside feature buffer
ERR: Failed to run classifier (-5)
I tried to increase the EI_CLASSIFIER_NN_INPUT_FRAME_SIZE but with no result. I think the problem is somewhere else.
Project ID: 679339
Thank you
Hi @kai0706
Can you share a screenshot of your Impulse configuration?
I guess that perhaps the window size is set too large and causes a OOM issue. Try lowering the window size.
