Tried to run my model in browser and it gave me err code -5. What does it mean?
Hello @zloberto,
I just checked your project, sorry for the delay.
In your impulse creation tab you set the sampling frequency to 1024Hz, but your audio samples are sampled at 44100Hz or 48000Hz depending on your samples. Is there any particular reason for this?
I suggest that you set the frequency to your lowest one in your data samples (44100Hz).
Also, is there any reason why you chose the spectral feature dsp block instead of an MFE or Spectrogram? Usually they work better with audio data.
You could try the EON tuner to find the best trade-off between model performances and model size.
Which hardware architecture are you targeting?
