Failed to get info off device timeout
Oh yeah, you were right. I was running both the Arduino IDE and trying to run the daemon at the same time. However, still having the same error as above:
Serial is connected, trying to read config...
[SER] Failed to get info off device Timeout when waiting for >  (timeout: 5000) onConnected
Any other tips?
try selecting another port
Hi @janjongboom kindly help. This is the issue i am facing. I am running Arduino Nano RP2040 on Ubuntu 20.04.5.
Setting upload host in device...Error while setting up device Error: Failed to set upload host: Traceback (most recent call last):
  File "<stdin>", line 1
SyntaxError: invalid syntax
    at EiSerialProtocol.setUploadHost (/path/.nvm/versions/node/v16.0.0/lib/node_modules/edge-impulse-cli/build/shared/daemon/ei-serial-protocol.js:298:19)
    at async setupWizard (/path/.nvm/versions/node/v16.0.0/lib/node_modules/edge-impulse-cli/build/cli/daemon.js:600:17)
    at async SerialConnector.connectLogic (nvm/versions/node/v16.0.0/lib/node_modules/edge-impulse-cli/build/cli/daemon.js:477:17)
[SER] Cannot connect to remote management API using daemon, failed to read apiKey, deviceId or deviceType from device. Restarting your development board might help. Retrying in 5 seconds...
[WS ] Failed to authenticate, API key not correct? Missing deviceId
Hi @aurel, I am running the Arduino Nano RP2040,however my i cant seem to register my device on edge pulse platform. I am trying to connect to device using chrome browser.
I suspect your Edge Impulse CLI is out-of-date.
Running the daemon…
C:\edge-impulse-daemon
Should result in…
Edge Impulse serial daemon v1.16.1
Endpoints:
    API:       https://studio.edgeimpulse.com
[SER] Connecting to COM5
[SER] Retrieved configuration
[SER] Device is running AT command version 1.7.0
To update the CLI…
C:\npm update -g edge-impulse-cli
flash the memory then try this…
Thank you worked like charm
You can try to delete the device and then connect it again.
Followed the instructions (Arduino Nano 33 BLE Sense | Edge Impulse Documentation ) but no luck to connect (Failed to get info off device Timeout).
Brief description of actions:
I installed the following software:
  1. Edge Impulse CLI
  2. Arduino CLI
Afterwards I succesfully updated the latest pre-built firmware for Arduino Nano 33 BLE
  1. Download the latest Edge Impulse firmware,
Then I runned edge-impulse-daemon and as you can see from the screenshot Serial closed and Failed to get info off device Timeout
Note whenever through Arduino IDE 2.3.3 I open Serial Monitor or Serial Plotter the Arduino Nano 33 BLE disconnects.
Just in case you ask, Arduino IDE 2.3.3 is not running when I run edge-impulse-daemon.
Any suggestions to solve the problem?
Everything works fine when connected to another Desktop PC.
But the problem appears when connected to laptop HP 255 g9 (6F293EA) (Ryzen3-5425u) usb ports!!!
I read somewhere that I must re-install the AMD graphics driver. It contains the chipset drivers, including the USB port drivers.
Below is the latest AMD grahics driver that is installed.
APU - AMD Radeon ™ Graphics - Primary/Integrated (VRAM - 512 MB - DDR4 1333 MHz)
Driver Version - 23.19.21.01-240819a-407052C-AMD-Software-Adrenalin-Edition
AMD Windows Driver Version - 31.0.21921.1000
UI Version - 2024.0819.1807.1996
AMD Audio Driver Version - 10.0.1.30
Driver Provider - Advanced Micro Devices, Inc.
Windows Edition - Windows 10 Professional (64 bit)
Windows Version - 22H2
Any suggestions ?
Solved !!!
Even though ARDUINO IDE works with Arduino Nano 33 BLE Sense Lite and fully communicate through the serial port (COM 5 or COM 4)
The edge-impulse-daemon continues to respond “Failed to get info off device…”
So something was going wrong with AMD USB 3.1 Extensible Host Controller 1.10 (Microsoft) and edge impulse serial daemon so I did the following :
  1. Re-installed AMD graphics driver (Adrenalin software)
  2. Afterwards I succesfully updated the latest pre-built firmware for Arduino Nano 33 BLE
    Download the latest Edge Impulse firmware ,
Then I runned edge-impulse-daemon --clean
All works fine !!!
Hi!
I am following this documentation Alif Ensemble series kits - Edge Impulse Documentation.
I’m facing this issue when running this command edge-impulse-daemon. Can you help me to troubleshoot this?
Edge Impulse serial daemon v1.36.0
Endpoints:
[SER] Connecting to /dev/ttyACM0
  • Ubuntu WSL
  • Alif E7 board
