Hi Edge Impulse community, I was not able to establish connection between Edge Impulse and my Thingy:91 with hardware version 1.6.0?Could you please help?
The below error message appears in terminal:
Can I make sure you followed this step in order to flash the firmware correctly?
Also, what is your hardware version?
Thingy:91 hardware version < 1.4.0
Updating the firmware with older hardware versions may fail. Moreover, even if the update works, the device may later fail to connect to Edge Impulse Studio:
In these cases, you will also need to flash the connectivity-bridge.hex onto the nRF52840 in the Thingy:91. Follow the steps here to update the nRF52840 SOC application with the connectivity-bridge.hex file through USB.
Hardware version is 1.6.0. I followed instructions, except flashing both hex files using an external probe. It was working before. I don’t know what was changed.
Hi @louis, again I spent almost 4 hours, and was not able to connect it…are you guys changed the firmware file recently, since it was working before?I was working on spring this year. I even tried different usb cables. Used another internet connection. What I am doing wrong here?
