Board: Himax WE-I Plus EVB
OS: MAC OSX 10.14.6
Edge Impulse serial daemon : v1.14.11
I followed the steps in this doc: Himax WE-I Plus - Edge Impulse Documentation
After flashing the Himax board, I tried to set up my development with Edge Impulse, by run ‘edge-impulse-daemon’
but I got
[SER] Failed to get info off device Timeout when waiting for > (timeout: 5000) onConnected.
Refer to some of the responses about this “Failed to get info off device Timeout……” issue; I have given several tries but get the same failure message.
Also, I had checked the Proxy setting and had changed different ports…
Could anyone give me a hint to solve this issue?
Thanks!
The relevant results of several attempts are posted below for your reference.
Flashing the firmware
response after : edge-impulse-daemon
edge-impulse-run-impulse
edge-impulse-daemon --clean
edge-impulse-run-impulse --raw
Flashing board…
[HMX] Connecting to /dev/tty.usbserial-DT044YP2…
[HMX] Connected, press the RESET button on your Himax WE-I now
[HMX] Restarted into bootloader. Sending file.
[HMX] Sending 3286 blocks
████████████████████████████████████████ 100% | ETA: 0s | 3286/3286
[HMX] Sent all blocks (NAK count: 4)
[HMX] Press RESET to start the application…
[HMX] Firmware update complete
Flashed your Himax WE-I Plus development board.
To set up your development with Edge Impulse, run ‘edge-impulse-daemon’
To run your impulse on your development board, run ‘edge-impulse-run-impulse’
logout
Saving session…
…copying shared history…
…saving history…truncating history files…
…completed.
[Process completed]
edge-impulse-daemon
Edge Impulse serial daemon v1.14.11
Endpoints:
[SER] Connecting to /dev/tty.usbserial-DT044YP2
Edge Impulse impulse runner v1.14.11
[SER] Failed to get info off device:undefined. Is this device running a binary built through Edge Impulse? Reconnecting in 5 seconds
? What is your user name or e-mail address (edgeimpulse.com)? WalterinTW
? What is your password? [hidden]
Endpoints:
(base) MacBook-Air:~ walter$ edge-impulse-run-impulse --raw
[SER] Connected to /dev/tty.usbserial-DT044YP2
