I’m trying to connect my nRF52833 DK board to the edge impulse. I gave edge-impulse-daemon cmd and I got the following error,
Connecting to COM6
How can I solve it? Thanks in advance.
You can’t connect directly to Edge Impulse studio without modifying the code, however, you can still use your board. To collect data, you can use the Data forwarder and you will be able to download the C++ library to run your impulse on your device.
