Failed to generate features
Can’t generate feature with no errors provided
Creating job... OK (ID: 40279816)
Job failed (see above)
- Add data using the folder conaining images and COCO JSON (275 items)
- Create an impulse with ‘Image’ preprocessing and ‘Object Detection’ learning block
- Try to generate features
Today we had an issue where some credentials were not renewed, which affected new jobs (which need those credentials). Unfortunately we only realized this after a few hours as the alerts did not go off properly for this. The issue has been resolved now, and we’ll make sure we’ll get proper monitoring in place in the future. Apologies here (and thanks for reporting).
Hi, I have the same problem with a project that was working fine yesterday. This is probably a backend issue.
-Heikki
