Hello, I’m trying to deploy my image classification EI project on a STM32L475VG-IOT01A board. I downloaded the Cube.MX CMSIS-PACK from EI and followed the tutorial provided by Edge Impulse (https://docs.edgeimpulse.com/docs/using-cubeai). The only thing I changed from the provided code is the following:
static const long features[] = {0xffffff, 0xffffff, …, 0xffffff, 0xffffff, 0xffffff};
int get_feature_data(size_t offset, size_t length, float *out_ptr) {
memcpy(out_ptr, features + offset, length * sizeof(long));
return 0;
Actually I only changed the features type from float to long(but the problem is present also with the float type). When I build the project I have 0 errors and 0 warnings, but when I try to run I got this on Putty:
Anyone could help me with this problem?
Thanks,
Angelo
