I have a lot data logged, from a bunch of instrumented machines, that is updated continiously, on google storage.
The format is proprietary, each datafile from one sensor is stored as 10 second timeseries data zipped into npz format - containing a file header, and a 500_000 item data array
I am able to connect to my google bucket by adding it as Data sources, but the data explorer step fails, i assume because of my custom data storage format.
However the log suggest that i have not yet created an impulse, which i cannot do before uploading any data
Checking if data explorer is rendered...
Checking if data explorer is rendered OK
Refreshing data explorer...
Scheduling job in cluster...
Creating data explorer job in Edge Impulse failed Data explorer preset not set, and no configured impulse
Job started
Job started
Job started
Job failed (see above)
So my two questions are :
- Will there be an option / feature to load custom dataformats, e.g. by providing a loader snippet
- Im a missing something rgd. creating an impulse before using connecting an external data source
