Question/Issue: After some research on Bard, to detect the direction that a flying sound object (a hornet) can take, I discovered that there were categories xstart, ystart, xend and yend of an edge impulse inference based on sound, but I can’t find a usage example. Would you have any?
Project ID: Berny/Frelon asiatique
**Context/Use case:**The characteristic sound emitted by a hornet in flight is around 230 Hz, if we place two microphones 2m apart the arrival difference is of the order of 10 to 15 ms, It is therefore a question of identifying the maximum difference between the Xstart then the Xend to hope to have the direction of the flight and hope to find the nest, in a non-aggressive or intrusive way (no active chip or not to stick on the hornet)
