How to interpret the results from EdgeImpulse?
I trained a YoloV5-medium model on approximately 2700 images. After testing it on the 20% of the images that is reserved for testing, i get an accuracy of 99.62%. That seems awesome.
However, when I open the logs of the test run it shows the following:
calculate_object_detection_metrics
{“support”: 533, “coco_map”: 0.9371042251586914, “coco_metrics”:
{“MaP”: 0.02786771954277207,
“MaP@[IoU=50]”: 0.12573883545581718,
“MaP@[IoU=75]”: 0.004394394864889173,
“MaP@[area=small]”: 0.02786771954277207,
“MaP@[area=medium]”: -1.0,
“MaP@[area=large]”: -1.0,
“Recall@[max_detections=1]”: 0.10357815442561205,
“Recall@[max_detections=10]”: 0.10357815442561205,
“Recall@[max_detections=100]”: 0.10357815442561205,
“Recall@[area=small]”: 0.10357815442561205,
“Recall@[area=medium]”: -1.0,
“Recall@[area=large]”: -1.0,
“support”: {“images”: 533, “annotations”: 533, “detections”: 531}},
“class_names”: [“queen”]}
I can see that:
These are very low scores and I am trying to understand why the accuracy given by EdgeImpulse (see picture below) is of 99.62% while the MaP (IoU 50 and 75) listed above is so low. In fact, it seems like the model was actually able to detect the test images correctly, I am just struggling to understand why those other scores are so low.
Is there a guide on how to interpret the results given by EdgeImpulse?
I can also see that “coco_map” (i assume coco mean average precision) is quite high. I was also wondering if anyone can interpret this, and why the rest is so low.
Interpretation of results
