I’m using an AI Thinker ESP32 and a FOMO model. I’d like to use grayscale but don’t know how to change the example so that it works.
There are so many parameters and if I don’t use RGB as raw features and a resolution of less than 240 pixels the script keeps throwing errors like:
Guru Meditation Error: Core 1 panic’ed (StoreProhibited). Exception was unhandled
Hi @Merten
I’m not sure what step you modified, which doc are you following?
The error you are having has been encountered previously please try following the steps listed here to debug your issue:
Yeah I know that I can change it there but the exported example program isn’t getting changed based on the settings I choose.
If you change the Color Depth
on the Image page, then you need to work down the left navigation tree again, aka, you must redo tasks on pages:
- Impulse Design - Object Detection
- [optional] EON Tuner
- [optional, if you selected a new model from the EON Tuner] Retrain model
- [optional] Model Testing <–NOTE: The
Set Confidence Threshold
value you set here DOES get deployed to the Deployed FOMO Model. - Deployment
