ESP32-S3 + OV3660 + Edge Impulse (EON, INT8): Inference always outputs same class at fixed confidence, and CORRUPT HEAP crash on fmt2rgb888 with PSRAM
Inference result is always fixed to the same class (“2”) with confidence ~0.996, regardless of what the camera sees. Additionally, when attempting to fix this issue by modifying the image capture buffer handling, a CORRUPT HEAP crash occurs after the first inference attempt, causing an infinite reboot loop.
Project ID: 983735
Building a real-time hand gesture recognition system using an ESP32-S3 with an OV3660 camera module. The camera captures JPEG frames, converts them to RGB888 via fmt2rgb888, resizes from 320×240 to 96×96 using Edge Impulse’s crop_and_interpolate_rgb888, then feeds grayscale float values to the classifier via getSignalData callback. A web server streams the live camera feed simultaneously.
  1. Captured JPEG frame from camera (QVGA 320×240), converted to RGB888 using fmt2rgb888, resized to 96×96 using crop_and_interpolate_rgb888, then passed grayscale float values to run_classifier via getSignalData callback.
  2. Confirmed camera buffer values change every inference cycle (capture itself is working):
buf[0]=167, buf[1]=168, buf[2]=165
buf[0]=108, buf[1]=114, buf[2]=113
buf[0]=216, buf[1]=222, buf[2]=228
  1. Fixed index calculation bug in getSignalData (changed offset*3 + i*3(offset+i)*3).
  2. Reduced snapshot_buf allocation from 320×240×3 to 96×96×3 since only resized data needs to be stored.
  3. Moved fmt2rgb888 target buffer from internal SRAM to PSRAM (MALLOC_CAP_SPIRAM) due to insufficient internal SRAM for a 230,400-byte buffer.
  4. Applied standard grayscale conversion formula: 0.299*r + 0.587*g + 0.114*b.
  5. Tried normalizing output to 0.0~1.0 range (gray / 255.0f).
Despite all of the above, inference result remains fixed at class “2” with confidence 0.996. Some modifications additionally triggered a CORRUPT HEAP crash on first inference.
The classifier should return different labels with varying confidence scores depending on the hand gesture shown to the camera, matching the behavior observed when testing the model directly on Edge Impulse’s platform using a smartphone.
Issue 1 — Fixed inference result:
Result: 2 (0.996)
Result: 2 (0.996)
Result: 2 (0.996)
The classifier always outputs class “2” at ~0.996 confidence regardless of input.
Issue 2 — CORRUPT HEAP crash (occurs after buffer handling modifications):
PSRAM remaining: 8312355 bytes
Internal heap: 256584 bytes
CORRUPT HEAP: Bad head at 0x3d813134. Expected 0xabba1234 got 0x68656868
assert failed: multi_heap_free multi_heap_poisoning.c:259 (head != NULL)
The device crashes on first inference and reboots infinitely.
  • [x] Always
  • Platform: ESP32-S3 DevKitC-1 (8MB Flash, 8MB PSRAM), OV3660 camera module
  • Build Environment Details: PlatformIO + Arduino framework, board_build.arduino.memory_type = qio_opi, EI_CLASSIFIER_TFLITE_ARENA_SIZE = 2097152
  • OS Version: Windows 11
  • Edge Impulse Version (Firmware):
    • EI_STUDIO_VERSION_MAJOR = 1
    • EI_STUDIO_VERSION_MINOR = 93
    • EI_STUDIO_VERSION_PATCH = 3
  • Edge Impulse CLI Version: N/A (library deployment)
  • Project Version: Deploy version 16
  • Custom Blocks / Impulse Configuration:
    • Input: Image 96×96, Grayscale, Resize mode: Fit shortest
    • DSP Block: Image (Grayscale)
    • Learning Block: Transfer Learning, MobileNetV2 96×96 0.35
    • Output: 6 classes (1, 2, 3, background, good, heart)
    • Inferencing engine: EON Compiler (INT8 quantized, EI_CLASSIFIER_COMPILED = 1)
    • EI_CLASSIFIER_TFLITE_INPUT_DATATYPE = INT8
    • EI_CLASSIFIER_LOAD_IMAGE_SCALING = 0
    • EI_CLASSIFIER_TFLITE_LARGEST_ARENA_SIZE = 256326
Relevant code — capture and inference:
bool captureImageForInference(uint32_t img_width, uint32_t img_height, uint8_t *out_buf) {
  camera_fb_t *fb = esp_camera_fb_get();
  uint8_t *tmp_buf = (uint8_t*)heap_caps_malloc(
    320 * 240 * 3, MALLOC_CAP_SPIRAM | MALLOC_CAP_8BIT);
  fmt2rgb888(fb->buf, fb->len, PIXFORMAT_JPEG, tmp_buf);
  esp_camera_fb_return(fb);
  ei::image::processing::crop_and_interpolate_rgb888(
    tmp_buf, 320, 240, out_buf, img_width, img_height);
  free(tmp_buf);
  return true;
static int getSignalData(size_t offset, size_t length, float *out_ptr) {
  for (size_t i = 0; i < length; i++) {
    size_t pixel_ix = (offset + i) * 3;
    uint8_t r = snapshot_buf[pixel_ix];
    uint8_t g = snapshot_buf[pixel_ix + 1];
    uint8_t b = snapshot_buf[pixel_ix + 2];
    out_ptr[i] = 0.299f * r + 0.587f * g + 0.114f * b;
  return 0;
signal_t signal;
signal.total_length = 96 * 96; // EI_CLASSIFIER_RAW_SAMPLE_COUNT = 9216
signal.get_data = &getSignalData;
run_classifier(&signal, &result, false);
  • The model works correctly when tested directly on Edge Impulse’s platform using a smartphone camera — all 6 classes are recognized properly.
  • The live camera stream on the web UI updates correctly, confirming the camera hardware and capture pipeline are functional.
  • We suspect one of the following may be the root cause: (1) fmt2rgb888 writing beyond the allocated PSRAM buffer boundary, (2) incorrect data format or value range expected by the EON-compiled INT8 model in getSignalData, or (3) PSRAM cache coherency issues when reading snapshot_buf inside the callback.
  • We are considering switching from PIXFORMAT_JPEG to PIXFORMAT_RGB888 to eliminate fmt2rgb888 entirely — would this approach be recommended?
Hi, @Sheum !
I believe manual conversion to grayscale is not necessary - we do that in our Image DSP block. Please try our original Arduino sketch and do not convert to grayscale. Let me know if it fixes the issue.
Hi @AIWintermuteAI,
Thank you so much for the accurate diagnosis! You were absolutely right. Passing the packed RGB values directly (r << 16) | (g << 8) | b without manual grayscale conversion resolved the data formatting issue perfectly. Disabling the EON Compiler also fixed the 0.996 output lock and the infinite crashing loop.
However, after fixing the code, we are currently suspecting another critical issue based on our hardware tests: a massive Domain Gap.
Here is how we reached this hypothesis through debugging:
  1. When we completely covered the camera lens, the classification for class ‘2’ maxed out at 0.996.
  2. Suspecting a lighting issue, we shined a smartphone flashlight directly at the ESP32 camera. Suddenly, the confidence for class ‘1’ started to fluctuate and increase.
  3. We checked the live camera feed via our local web server and noticed the image was extremely dark and noisy compared to our training dataset, even with the ceiling lights on. (We also tried extending the camera cable and adjusting the lens focus, but the fundamental sensor limitation remains.)
Since our model was primarily trained on high-quality, well-lit smartphone images, we strongly suspect that the OV3660 module’s hardware limitations are causing it to see a mostly black, noisy screen, which the model currently misinterprets as class ‘2’.
To verify this hypothesis, we plan to temporarily exclude the smartphone dataset and retrain the model exclusively using images captured directly from the ESP32 camera to match the target environment.
Thanks again for pointing us in the right direction!
