I am looking to use the data ingestion api to collect audio data (short segments of machine sounds from a woodshop) and sent it by http(s) POST.
So far…
I have successfully run the data ingestion c++ example via win10 WSL2 linux.
Any suggestions for changes that might be needed to run it via esp-idf or arduino framework?
Any HTTP library should work there, e.g. https://randomnerdtutorials.com/esp32-http-get-post-arduino/ if you’re also using the Arduino IDE.
This is how we do it on another target:
httplib::Client cli("http://ingestion.edgeimpulse.com");
httplib::Headers headers = {
{ "x-api-key", API_KEY },
{ "x-file-name", "linuxtest01.cbor" },
{ "x-label", "linuxtest" },
{ "x-disallow-duplicates", "1" },
{ "content-type", "application/cbor" }
// you can replace 'training' here with 'testing'
auto http_res = cli.Post("/api/training/data", headers, (const char*)buffer, len, "application/cbor");
printf("Uploaded data, status=%d, body=%s\n", http_res->status, http_res->body.c_str());
Here buffer is the data in Edge Impulse data acquisition format, and len is the length of the buffer.
