Hi everyone I have been able to get the ESP32 to work with the edge impulse library and get my microphone working however it seems to be laggy, and I am trying to find a way to optimize the “hearing” aspect. When saying a word it may take about a second for the led to turn on. If anyone has any ideas I would greatly appreciate it!
#include <driver/i2s.h>
#include <Sylo_inferencing.h>
int LED = 13;
long prev = 0;
void TaskMic( void *pvParameters );
bool semaphore = false;
float features[16000];
//float features_mic[16000];
return 0;
va_list args;
va_start(args, format);
va_end(args);
if (r > 0) {
Serial.write(print_buf);
const i2s_port_t I2S_PORT = I2S_NUM_0;
const int BLOCK_SIZE = 1000;
void setup() {
Serial.begin(115200);
pinMode(LED, OUTPUT);
Serial.println("Configuring I2S...");
esp_err_t err;
// The I2S config as per the example
const i2s_config_t i2s_config = {
.mode = i2s_mode_t(I2S_MODE_MASTER | I2S_MODE_RX), // Receive, not transfer
.sample_rate = 16000, // 16KHz
.bits_per_sample = I2S_BITS_PER_SAMPLE_32BIT, // could only get it to work with 32bits
.channel_format = I2S_CHANNEL_FMT_ONLY_LEFT, // although the SEL config should be left, it seems to transmit on right
.communication_format = i2s_comm_format_t(I2S_COMM_FORMAT_I2S | I2S_COMM_FORMAT_I2S_MSB),
.intr_alloc_flags = ESP_INTR_FLAG_LEVEL1, // Interrupt level 1
.dma_buf_count = 10, // number of buffers
.dma_buf_len = BLOCK_SIZE // samples per buffer
// The pin config as per the setup
const i2s_pin_config_t pin_config = {
.bck_io_num = 14, // BCKL
.ws_io_num = 15, // LRCL
.data_out_num = -1, // not used (only for speakers)
.data_in_num = 32 // DOUT
// Configuring the I2S driver and pins.
// This function must be called before any I2S driver read/write operations.
err = i2s_driver_install(I2S_PORT, &i2s_config, 0, NULL);
if (err != ESP_OK) {
Serial.printf("Failed installing driver: %d\n", err);
while (true);
err = i2s_set_pin(I2S_PORT, &pin_config);
Serial.printf("Failed setting pin: %d\n", err);
while (true);
Serial.println("I2S driver installed.");
// xTaskCreatePinnedToCore(
// TaskMic
// , "TaskMic" // A name just for humans
// , 10024 // This stack size can be checked & adjusted by reading the Stack Highwater
// , NULL
// , 2 // Priority, with 3 (configMAX_PRIORITIES - 1) being the highest, and 0 being the lowest.
// , NULL
// , 0);
void loop() {
int32_t samples[BLOCK_SIZE];
int num_bytes_read = i2s_read_bytes(I2S_PORT,
(char *)samples,
BLOCK_SIZE * 4, // the doc says bytes, but its elements.
portMAX_DELAY); // no timeout
int samples_read = num_bytes_read / 8;
long tr = millis();
long raz = tr - prev;
prev = tr;
semaphore = true;
while(semaphore){
for (int i = 0; i < 16000; i++) {
if (i < 15000) {
features[i] = features[i + 1000];
} else {
features[i] = (float)samples[i - 15000];
semaphore = false;
if (sizeof(features) / sizeof(float) != EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE) {
ei_printf("The size of your 'features' array is not correct. Expected %lu items, but had %lu\n",
delay(1000);
return;
// the features are stored into flash, and we don't want to load everything into RAM
signal_t features_signal;
// invoke the impulse
EI_IMPULSE_ERROR res = run_classifier(&features_signal, &result, false /* debug */);
int ind = -1;
float maxx = 0.0;
for (int in = 0; in < EI_CLASSIFIER_LABEL_COUNT; in++) {
if (result.classification[in].value > maxx && result.classification[in].value > 0.80) {
maxx = result.classification[in].value;
ind = in;
if (ind >= 0) {
String to_prnt = "";
to_prnt += result.classification[ind].label;
to_prnt += " ";
to_prnt += result.classification[ind].value;
Serial.println(to_prnt);
if (res != 0) return;
// print the predictions
ei_printf("Predictions ");
ei_printf(": \n");
ei_printf("[");
ei_printf("%.5f", result.classification[ix].value);
ei_printf(", ");
#else
ei_printf(", ");
#endif
ei_printf("%.3f", result.anomaly);
#endif
ei_printf("]\n");
// human-readable predictions
#endif
if(result.classification[2].value > 0.8){
digitalWrite(LED, HIGH);
delay(1000);
digitalWrite(LED, LOW);
delay(10);
