ESP32 Arduino; gray scale
Hi guys,
first of all congratulations on the project as it seems to be promising.
I am trying to train a binary image classification, I am using esp32 CAM.
I met some problems with allocating tensors, so I scaled down my images to 48x48 and used a different model and it works, even though I got bad performances (probably because the training set is created by my phone and then inference in the esp32).
I have got a question, If I use a gray scale mode and an image size 96x96, I might achieve better performance, but I get problems when allocating memory here:
dl_matrix3du_t *ei_matrix = dl_matrix3du_alloc(1, EI_CLASSIFIER_INPUT_WIDTH, EI_CLASSIFIER_INPUT_HEIGHT, 3);
As I use a grayscale (as an attempt), I can use just one channel and not 3.
Do you think I can replace 3 with 1 in the above methods and also in some mores where 3 is passed?
@louis can help with the ESP32 code, but yeah, I think you should alloc with the value found in the config of the DSP block rather than hardcoded as 3.
Note that you can replace by a MobileNetV1 block, they use a lot less memory - probably makes sense on the ESP32!
I tried this one:
#include “esp_camera.h”
#include <WiFi.h>
#include “soc/soc.h”
#include “soc/rtc_cntl_reg.h”
#include “img_converters.h”
#include <HTTPClient.h>
#include “image_util.h”
#include <edge7-project-1_inferencing.h>
// WARNING!!! Make sure that you have either selected ESP32 Wrover Module,
// or another board which has PSRAM enabled
//this edit code doesn’t use a gzipped html source code
//the html -code is open and is easy to update or modify on the other tab page = app_httpd.cpp
// Select camera model
//#define CAMERA_MODEL_WROVER_KIT
//#define CAMERA_MODEL_M5STACK_PSRAM
#define CAMERA_MODEL_AI_THINKER
#include “camera_pins.h”
const char* ssid = “FASTWEB-952LR7”;
const char* password = “LXUUATZ6CL”;
int channels = 1;
uint8_t *out_buf;
uint8_t *ei_buf;
static int8_t ei_activate = 0;
ei_impulse_result_t result = {0};
typedef struct
size_t size; //number of values used for filtering
size_t index; //current value index
size_t count; //value count
int sum;
int *values; //array to be filled with values
} ra_filter_t;
void setup() {
//WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); //disable brownout detector
Serial.begin(115200);
Serial.setDebugOutput(true);
Serial.println();
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_GRAYSCALE;
//init with high specs to pre-allocate larger buffers
if(psramFound()){
config.frame_size = FRAMESIZE_240X240;
config.jpeg_quality = 10;
config.fb_count = 2;
} else {
config.jpeg_quality = 12;
config.fb_count = 1;
// camera init
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf(“Camera init failed with error 0x%x”, err);
return;
//drop down frame size for higher initial frame rate
s->set_framesize(s, FRAMESIZE_240X240);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println(“WiFi connected”);
//startCameraServer();
Serial.print(“Camera Ready! Use 'http://”);
Serial.print(WiFi.localIP());
Serial.println("’ to connect, the stream is on a different port channel 9601 “);
Serial.print(“stream Ready! Use 'http://”);
Serial.println(”:9601/stream “);
Serial.print(“image Ready! Use 'http://”);
Serial.println(”/capture ");
void inference_handler()
camera_fb_t *fb = NULL;
int64_t fr_start = esp_timer_get_time();
size_t out_len, out_width, out_height;
size_t ei_len;
fb = esp_camera_fb_get();
if (!fb)
    Serial.println("Camera capture failed");
    return;
bool s;
bool detected = false;
dl_matrix3du_t *image_matrix = dl_matrix3du_alloc(1, fb->width, fb->height, channels);
if (!image_matrix)
    esp_camera_fb_return(fb);
    Serial.println("dl_matrix3du_alloc failed");
    return ;
out_buf = image_matrix->item;
out_len = fb->width * fb->height * channels;
out_width = fb->width;
out_height = fb->height;
Serial.println("Converting to RGB888...");
int64_t time_start = esp_timer_get_time();
// s = fmt2rgb888(fb->buf, fb->len, fb->format, out_buf);
int64_t time_end = esp_timer_get_time();
Serial.printf("Done in %ums\n", (uint32_t)((time_end - time_start) / 1000));
/*if (!s)
    dl_matrix3du_free(image_matrix);
    Serial.println("to rgb888 failed");
    return ;
dl_matrix3du_t *ei_matrix = dl_matrix3du_alloc(1, EI_CLASSIFIER_INPUT_WIDTH, EI_CLASSIFIER_INPUT_HEIGHT, channels);
if (!ei_matrix)
    return ;
ei_buf = ei_matrix->item;
ei_len = EI_CLASSIFIER_INPUT_WIDTH * EI_CLASSIFIER_INPUT_HEIGHT * channels;
Serial.println("Resizing the frame buffer...");
image_resize_linear(ei_buf, out_buf, EI_CLASSIFIER_INPUT_WIDTH, EI_CLASSIFIER_INPUT_HEIGHT, channels, out_width, out_height);
classify();
dl_matrix3du_free(ei_matrix);
int64_t fr_end = esp_timer_get_time();
//Serial.printf("JPG: %uB %ums\n", (uint32_t)(jchunk.len), (uint32_t)((fr_end - fr_start) / 1000));
return;
int raw_feature_get_data(size_t offset, size_t length, float *signal_ptr)
memcpy(signal_ptr, ei_buf + offset, length * sizeof(float));
return 0;
void classify()
Serial.println(“Getting signal…”);
// Set up pointer to look after data, crop it and convert it to RGB888
signal_t signal;
signal.total_length = EI_CLASSIFIER_INPUT_WIDTH * EI_CLASSIFIER_INPUT_WIDTH;
signal.get_data = &raw_feature_get_data;
Serial.println("Run classifier...");
// Feed signal to the classifier
EI_IMPULSE_ERROR res = run_classifier(&signal, &result, false /* debug */);
// Returned error variable "res" while data object.array in "result"
if (res != 0)
    return;
// print the predictions
ei_printf("Predictions ");
ei_printf("(DSP: %d ms., Classification: %d ms., Anomaly: %d ms.)", result.timing.dsp, result.timing.classification, result.timing.anomaly);
ei_printf(": \n");
// Print short form result data
ei_printf("[");
for (size_t ix = 0; ix < EI_CLASSIFIER_LABEL_COUNT; ix++)
    ei_printf("%.5f", result.classification[ix].value);
ei_printf(", “);
#else
if (ix != EI_CLASSIFIER_LABEL_COUNT - 1)
ei_printf(”, ");
#endif
ei_printf("%.3f", result.anomaly);
#endif
ei_printf("]\n");
double max_class = -1;
String value = “”;
// human-readable predictions
if (result.classification[ix].value > max_class){
value = result.classification[ix].label;
max_class = result.classification[ix].value;
#endif
Serial.println(value);
Serial.println(max_class);
HTTPClient http;
http.begin("http://192.168.1.56:8080/api/data/recognise");
http.addHeader("Content-Type", "application/json");
String jsonToSend = String("{\"recognised\":\"_TMP1_\",\"prob\":_TMP_}");
jsonToSend.replace("_TMP1_", value);
jsonToSend.replace("_TMP_", String(max_class));
Serial.println((jsonToSend));
http.POST(jsonToSend);
//free(ei_buf);
void loop() {
// put your main code here, to run repeatedly:
inference_handler();
delay(10000);
Sorry for the mess, basically I changed the camera config here:
added a channel variable and commented out this:
fmt2rgb888
However, I get:
using Input layer (9,216 features)
MobileNetV1 0.25 (final layer: 4 neurons, 0.1 dropout)
GrayScale. I think I would need to stick with 48x48.
Hello @edge7,
Indeed, the example provided only works for RGB at the moment.
Having a look at your error: using Input layer (9,216 features), you can see that you are still passing 48x48x3 features instead of 48x48 (2,304 features).
Can your try declaring a variable at the beginning of your inference_handler function:
int channels = 1;
Not 100% sure it will work but it worth giving a try.
I’ll have a look later this week at the ESP32 code example and will try to make it more generic and easier to understand.
Hey,
you are right.
I have set Grayscale here:
but I still see this when training the network:
maybe am missing a step?
As @janjongboom said,
Could you try using the MobileNet v1 architecture with RGB and 96x96 pixels, this model should fit in the ESP32. I’ll try myself too later. I’ll let you know how it goes.
yes, it works. I am able to upload it.
