We are trying to deploy the example model from the tutorial from the GitHub README (https://www.survivingwithandroid.com/tinyml-esp32-cam-edge-image-classification-with-edge-impulse/)
on our ESP-EYE device.
When using the most basic model (MobileNetV2 96x96 0.05) in Edge-Impulse the deployment works but the model is not accurate. Every other model fails with the following errors:
When deploying the model with the default partitions scheme we are getting the following error:
WiFi connected
Starting web server on port: ‘80’
Starting stream server on port: ‘81’
Camera Ready! Use http:// 192.168.1.158 to connect
Capture image
ERR: Failed to run DSP process (-1002)
run_classifier returned: -5 -
When deploying the model in arduino IDE using the “Huge APP” partition scheme we are getting the following error:
WiFi connected
Camera Ready! Use ‘http:// 192.168.1.158’ to connect
Capture image
run_classifier returned: -6
The ESP-EYE has 4MB of memory available.
According to the arduino IDE, the code itself takes ~1.2MB of memory.
According to the Edge-Impulse website, all models do not need more than 1MB of additional memory. However, it seems that the memory is the issue here.
Adding a screenshot of our board settings in arduino IDE:
Can you please advise on how can we make the more complicated models work on our device?
Thank you!
