Error XGBoost Classifier
When I run the classification with XGBoost, I receive this message:
“This model won’t run on MCUs. Verifying model failed with code -6 and no error message”
How can I resolve it?
**Project ID: 400273
@Emanuele280594 Thanks for reporting this issue! We’ve identified the cause of this issue and we’ll release a fix in the coming days. I’ll post an update in this thread as soon as the fix is live.
@Emanuele280594 The fix for this issue has been deployed, and I have verified that it resolves the issue for your project. You will need to re-train your model, after re-training “This model won’t run on MCUs. Verifying model failed with code -6 and no error message” error should disappear.
Please let us know if the fix does not work as expected.
Thank you for your response.
I confirm that the solution works and the issue has been resolved, thank you very much.
