I am new to Edge Impulse and I am certainly doing something wrong but have no idea what it is. What I have is 20 files with sensor data like this to train my model:
timestamp,exercise,sample,ACC X,ACC Y,ACC Z,GYR X,GYR Y,GYR Z,MAG X,MAG Y,MAG Z
-26045, 1, 20, -162, 203, 994, 0, -31, -4, -111, -411, -211
-26039, 1, 20, -144, 197, 961, -7, -27, 0, -109, -412, -222
Each file has the records for one sample and has (roughly) between 90 and 120 lines. These are the readings for a patient moving her leg up and down. I want to train a model for anomaly detection.
This is what I have done so far:
Create new project selecting âSomething elseâ.
In âData acquisitionâ, I uploaded 18 files using the âUpload dataâ option. My files are in csv format. (It took me a lot of time to figure out how to pass the timestamp. It would be great to have more detailed specifications about the data format required by the system).
âUpload dataâ screen, I have tried both âAutomatically split between training and testingâ and âTrainingâ, having similar issues. For label, I wrote âEx_1â.
I click "Begin Upload and it works fine.
Go to âCreate impulseâ and this is where all my problems start. The default values on screen are: Axes: 1000ms, Window increase: 1000ms, Frequency (Hz): 166.66666666666666, Zero-pad data: Selected.
Add âSpectral Analysisâ as processing block. (Tried with Flatten and Spectogram and got the same issues).
Add âAnomaly Detection (K-means)â as learning block.
Click on âSave Impulse.â
Go to âSpectral Featuresâ. These are the parameters I found:
Click on âSave parametersâ.
In âGenerate featuresâ, I get this:
Data in training set: 12s
Classes: 1 (Ex_1)
Window length: 1000 ms.
Window Increase: 1000 ms.
Training windows: 0
12.Click on âGenerate featuresâ and I get this error:
Creating job... OK (ID: 1821099)
Scheduling job in cluster...
Job started
Creating windows from 18 files...
[ 0/18] Creating windows from files...
[ 1/18] Creating windows from files...
[18/18] Creating windows from files...
[ 1/18] Resampling windows...
File "/app/input-block-preprocessing/downsample.py", line 86, in <module>
window = sn.resample_poly(window, target_freq, sample_freq, axis=ds_axis)
File "/usr/local/lib/python3.7/dist-packages/scipy/signal/signaltools.py", line 3089, in resample_poly
h = firwin(2 * half_len + 1, f_c, window=window)
File "/usr/local/lib/python3.7/dist-packages/scipy/signal/fir_filter_design.py", line 457, in firwin
m = np.arange(0, numtaps) - alpha
MemoryError: Unable to allocate array with shape (166666666666666656,) and data type int64
Error windowing Downsample error code was not 0, but was 1
Job failed (see above)
What am I doing wrong?
Thanks for your help.
Alvaro
Will fix this by limiting the max. resolution here while downsampling. In the short term you can fix this by changing the
