I am trying to upload speech data for training a keyword spotting model on Thunderboard sense 2. I have uploaded the edge impulse firmware and run demo codes using simplicity studio. But I am facing error while sampling through edge impulse cli and browser.
ERROR:
Microsoft Windows [Version 10.0.19044.1889]
(c) Microsoft Corporation. All rights reserved.
C:\Users\disha>edge-impulse-daemon
Edge Impulse serial daemon v1.15.1
Endpoints:
[SER] Connecting to COM7
[SER] Retrieved configuration
[SER] Device is running AT command version 1.3.0
Setting upload host in device… OK
Configuring remote management settings… OK
Configuring API key in device… OK
Configuring HMAC key in device… OK
[SER] Device is not connected to remote management API, will use daemon
[WS ] Device “Thunderboard” is now connected to project “keyword detection”
[WS ] Go to Login - Edge Impulse to build your machine learning model!
path: ‘/api/training/data’,
label: ‘test1’,
length: 5000,
interval: 16,
hmacKey: ‘769be16f3a9ade987a5c6e93d21c617e’,
sensor: ‘Built-in accelerometer’
[SER] Configured upload settings
[SER] Received stop signal, stopping application… Press CTRL+C again to force quit.
Terminate batch job (Y/N)? y
Endpoints:
label: ‘test1’,
length: 5000,
interval: 16,
[SER] Serial closed - retrying in 5 seconds
[WS ] Trying to connect in 1 second…
[SER] Cannot connect to remote management API using daemon, failed to read apiKey, deviceId or deviceType from device. Restarting your development board might help. Retrying in 5 seconds…
[WS ] Failed to sample data Error when communicating with device: Sampling settings:
Interval: 16 ms.
Length: 5000 ms.
HMAC Key: 769be16f3a9ade987a5c6e93d21c617e
File name: /fs/test1
Samples req: 312
Starting in 2000 ms… (or until all flash was erased)
b
Not a valid AT command (b)
[WS ] received message { err: ‘not authenticated, send “hello” first’, auth: false }
[SER] Failed to get info off device Error: Cannot parse sensor line: Nam
at EiSerialProtocol.getConfig (C:\Users\disha\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\shared\daemon\ei-serial-protocol.js:155:31)
at async SerialConnector.connectLogic (C:\Users\disha\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\daemon.js:482:26)
at async Timeout.connectLogic [as _onTimeout] (C:\Users\disha\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\daemon.js:455:22)
Endpoints:
label: ‘test1’,
length: 1000,
interval: 10,
[SER] Device not connected to WiFi directly, reading from buffer (bytes 0 - 1872, expecting to read ~2496 bytes…
[SER] Reading 101% complete…
[SER] Reading from buffer OK
[SER] File is 1872 bytes after decoding
[SER] Uploading to https://ingestion.edgeimpulse.com/api/training/data
[SER] Failed to upload to https://ingestion.edgeimpulse.com/api/training/data StatusCodeError: 400 - “Missing protected header”
at new StatusCodeError (C:\Users\disha\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\request-promise-core\lib\errors.js:32:15)
at Request.plumbing.callback (C:\Users\disha\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\request-promise-core\lib\plumbing.js:104:33)
at Request.RP$callback [as _callback] (C:\Users\disha\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\request-promise-core\lib\plumbing.js:46:31)
at Request.self.callback (C:\Users\disha\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\request\request.js:185:22)
at Request.emit (events.js:400:28)
at Request. (C:\Users\disha\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\request\request.js:1161:10)
at IncomingMessage. (C:\Users\disha\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\request\request.js:1083:12)
at Object.onceWrapper (events.js:519:28)
at IncomingMessage.emit (events.js:412:35)
at endReadableNT (internal/streams/readable.js:1317:12)
at processTicksAndRejections (internal/process/task_queues.js:82:21) {
statusCode: 400,
error: ‘Missing protected header’,
options: {
headers: {
‘x-api-key’: ‘ei_6c211c6796b89e1f0666014e1fc18047ea242c4e8e283ead157923357d82c192’,
‘x-file-name’: ‘test1’,
‘Content-Type’: ‘application/cbor’
body: <Buffer 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 … 1822 more bytes>,
encoding: ‘binary’,
uri: ‘https://ingestion.edgeimpulse.com/api/training/data’,
method: ‘POST’,
callback: [Function: RP$callback],
transform: undefined,
simple: true,
resolveWithFullResponse: false,
transform2xxOnly: false
response: <ref 1> IncomingMessage {
_readableState: ReadableState {
objectMode: false,
highWaterMark: 16384,
buffer: BufferList { head: null, tail: null, length: 0 },
length: 0,
pipes: [],
flowing: true,
ended: true,
endEmitted: true,
reading: false,
sync: false,
needReadable: false,
emittedReadable: false,
readableListening: false,
resumeScheduled: false,
errorEmitted: false,
emitClose: true,
autoDestroy: false,
destroyed: false,
errored: null,
closed: false,
closeEmitted: false,
defaultEncoding: ‘utf8’,
awaitDrainWriters: null,
multiAwaitDrain: false,
readingMore: false,
decoder: [StringDecoder],
encoding: ‘latin1’,
[Symbol(kPaused)]: false
_events: [Object: null prototype] {
end: [Array],
close: [Array],
data: [Function (anonymous)],
error: [Function (anonymous)]
_eventsCount: 4,
_maxListeners: undefined,
socket: TLSSocket {
_tlsOptions: [Object],
_secureEstablished: true,
_securePending: false,
_newSessionPending: false,
_controlReleased: true,
secureConnecting: false,
_SNICallback: null,
servername: ‘ingestion.edgeimpulse.com’,
alpnProtocol: false,
authorized: true,
authorizationError: null,
encrypted: true,
_events: [Object: null prototype],
_eventsCount: 10,
connecting: false,
_hadError: false,
_parent: null,
_host: ‘ingestion.edgeimpulse.com’,
_readableState: [ReadableState],
_writableState: [WritableState],
allowHalfOpen: false,
_sockname: null,
_pendingData: null,
_pendingEncoding: ‘’,
server: undefined,
_server: null,
ssl: [TLSWrap],
_requestCert: true,
_rejectUnauthorized: true,
parser: null,
_httpMessage: [ClientRequest],
[Symbol(res)]: [TLSWrap],
[Symbol(verified)]: true,
[Symbol(pendingSession)]: null,
[Symbol(async_id_symbol)]: 537,
[Symbol(kHandle)]: [TLSWrap],
[Symbol(kSetNoDelay)]: false,
[Symbol(lastWriteQueueSize)]: 0,
[Symbol(timeout)]: null,
[Symbol(kBuffer)]: null,
[Symbol(kBufferCb)]: null,
[Symbol(kBufferGen)]: null,
[Symbol(kCapture)]: false,
[Symbol(kBytesRead)]: 0,
[Symbol(kBytesWritten)]: 0,
[Symbol(connect-options)]: [Object],
[Symbol(RequestTimeout)]: undefined
httpVersionMajor: 1,
httpVersionMinor: 1,
httpVersion: ‘1.1’,
complete: true,
headers: {
date: ‘Wed, 17 Aug 2022 10:32:12 GMT’,
‘content-type’: ‘text/plain’,
‘transfer-encoding’: ‘chunked’,
connection: ‘close’,
‘access-control-allow-origin’: '’,
‘content-security-policy’: “default-src ‘none’; frame-ancestors ‘none’; form-action ‘none’;”,
‘x-content-type-options’: ‘nosniff’,
‘x-frame-options’: ‘DENY’,
‘x-xss-protection’: ‘1; mode=block’,
‘referrer-policy’: ‘strict-origin’,
‘cache-control’: ‘s-maxage=0,public,no-cache,no-store,must-revalidate’,
‘strict-transport-security’: ‘max-age=63072000’
rawHeaders: [
‘Date’,
‘Content-Type’,
‘text/plain’,
‘Transfer-Encoding’,
‘chunked’,
‘Connection’,
‘close’,
‘Access-Control-Allow-Origin’,
‘Content-Security-Policy’,
‘X-Content-Type-Options’,
‘nosniff’,
‘X-Frame-Options’,
‘DENY’,
‘X-XSS-Protection’,
‘1; mode=block’,
‘Referrer-Policy’,
‘strict-origin’,
‘Cache-Control’,
‘Strict-Transport-Security’,
‘max-age=63072000’
trailers: {},
rawTrailers: [],
aborted: false,
upgrade: false,
url: ‘’,
method: null,
statusCode: 400,
statusMessage: ‘Bad Request’,
client: TLSSocket {
_SNICallback: null,
authorized: true,
encrypted: true,
_eventsCount: 10,
connecting: false,
_hadError: false,
_parent: null,
_sockname: null,
_pendingData: null,
server: undefined,
_server: null,
ssl: [TLSWrap],
_requestCert: true,
parser: null,
_consuming: true,
_dumped: false,
req: ClientRequest {
_eventsCount: 5,
outputData: [],
outputSize: 0,
writable: true,
destroyed: false,
_last: true,
chunkedEncoding: false,
shouldKeepAlive: false,
_defaultKeepAlive: true,
useChunkedEncodingByDefault: true,
sendDate: false,
_removedConnection: false,
_removedContLen: false,
_removedTE: false,
_contentLength: null,
_hasBody: true,
_trailer: ‘’,
finished: true,
_headerSent: true,
socket: [TLSSocket],
_header: ‘POST /api/training/data HTTP/1.1\r\n’ +
‘x-api-key: ei_6c211c6796b89e1f0666014e1fc18047ea242c4e8e283ead157923357d82c192\r\n’ +
‘x-file-name: test1\r\n’ +
‘Content-Type: application/cbor\r\n’ +
‘host: ingestion.edgeimpulse.com\r\n’ +
‘content-length: 1872\r\n’ +
‘Connection: close\r\n’ +
‘\r\n’,
_keepAliveTimeout: 0,
_onPendingData: [Function: noopPendingOutput],
agent: [Agent],
socketPath: undefined,
method: ‘POST’,
maxHeaderSize: undefined,
insecureHTTPParser: undefined,
_ended: true,
res: [Circular *1],
aborted: false,
timeoutCb: null,
upgradeOrConnect: false,
parser: null,
maxHeadersCount: null,
reusedSocket: false,
protocol: ‘https:’,
[Symbol(kNeedDrain)]: false,
[Symbol(corked)]: 0,
[Symbol(kOutHeaders)]: [Object: null prototype]
request: Request {
_eventsCount: 5,
headers: [Object],
encoding: ‘binary’,
uri: [Url],
method: ‘POST’,
readable: true,
writable: true,
explicitMethod: true,
_qs: [Querystring],
_auth: [Auth],
_oauth: [OAuth],
_multipart: [Multipart],
_redirect: [Redirect],
_tunnel: [Tunnel],
_rp_resolve: [Function (anonymous)],
_rp_reject: [Function (anonymous)],
_rp_promise: [Promise [Object]],
_rp_callbackOrig: undefined,
callback: [Function (anonymous)],
_rp_options: [Object],
setHeader: [Function (anonymous)],
hasHeader: [Function (anonymous)],
getHeader: [Function (anonymous)],
removeHeader: [Function (anonymous)],
localAddress: undefined,
pool: {},
dests: [],
__isRequestRequest: true,
_callback: [Function: RP$callback],
proxy: null,
tunnel: true,
setHost: true,
originalCookieHeader: undefined,
_disableCookies: true,
_jar: undefined,
port: 443,
httpModule: [Object],
agentClass: [Function: Agent],
agent: [Agent],
_started: true,
href: ‘https://ingestion.edgeimpulse.com/api/training/data’,
req: [ClientRequest],
ntick: true,
response: [Circular *1],
originalHost: ‘ingestion.edgeimpulse.com’,
originalHostHeaderName: ‘host’,
responseContent: [Circular 1],
_destdata: true,
_ended: true,
_callbackCalled: true,
toJSON: [Function: responseToJSON],
caseless: Caseless { dict: [Object] },
body: ‘Missing protected header’,
label: ‘test1’,
length: 1000,
interval: 16,
[SER] Sampling started
[SER] Sampling done
[SER] Device not connected to WiFi directly, reading from buffer (bytes 0 - 1264, expecting to read ~1685 bytes…
[SER] File is 1264 bytes after decoding
statusCode: 400,
options: {
headers: {
body: <Buffer 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 … 1214 more bytes>,
encoding: ‘binary’,
method: ‘POST’,
simple: true,
objectMode: false,
length: 0,
pipes: [],
flowing: true,
ended: true,
endEmitted: true,
reading: false,
sync: false,
emitClose: true,
autoDestroy: false,
destroyed: false,
errored: null,
closed: false,
readingMore: false,
encoding: ‘latin1’,
end: [Array],
close: [Array],
_eventsCount: 4,
socket: TLSSocket {
_SNICallback: null,
authorized: true,
encrypted: true,
_eventsCount: 10,
connecting: false,
_hadError: false,
_parent: null,
_sockname: null,
_pendingData: null,
server: undefined,
_server: null,
ssl: [TLSWrap],
_requestCert: true,
parser: null,
[Symbol(async_id_symbol)]: 819,
httpVersion: ‘1.1’,
complete: true,
headers: {
date: ‘Wed, 17 Aug 2022 10:34:07 GMT’,
rawHeaders: [
‘Date’,
‘Content-Type’,
‘text/plain’,
‘chunked’,
‘Connection’,
‘close’,
‘nosniff’,
‘X-Frame-Options’,
‘DENY’,
‘X-XSS-Protection’,
‘1; mode=block’,
‘Referrer-Policy’,
‘strict-origin’,
‘Cache-Control’,
‘max-age=63072000’
trailers: {},
rawTrailers: [],
aborted: false,
upgrade: false,
url: ‘’,
method: null,
statusCode: 400,
client: TLSSocket {
_SNICallback: null,
authorized: true,
encrypted: true,
_eventsCount: 10,
connecting: false,
_hadError: false,
_parent: null,
_sockname: null,
_pendingData: null,
server: undefined,
_server: null,
ssl: [TLSWrap],
_requestCert: true,
parser: null,
_consuming: true,
_dumped: false,
_eventsCount: 5,
outputData: [],
outputSize: 0,
writable: true,
destroyed: false,
_last: true,
sendDate: false,
_removedTE: false,
_hasBody: true,
_trailer: ‘’,
finished: true,
_headerSent: true,
‘content-length: 1264\r\n’ +
‘\r\n’,
agent: [Agent],
method: ‘POST’,
_ended: true,
res: [Circular *1],
aborted: false,
timeoutCb: null,
parser: null,
protocol: ‘https:’,
request: Request {
_eventsCount: 5,
headers: [Object],
encoding: ‘binary’,
uri: [Url],
method: ‘POST’,
readable: true,
writable: true,
_qs: [Querystring],
_auth: [Auth],
_oauth: [OAuth],
_tunnel: [Tunnel],
pool: {},
dests: [],
proxy: null,
tunnel: true,
setHost: true,
_jar: undefined,
port: 443,
agent: [Agent],
_started: true,
ntick: true,
responseContent: [Circular *1],
_destdata: true,
_ended: true,
label: ‘test1’,
length: 1000,
interval: 0.0625,
sensor: ‘Built-in microphone’
[SER] Device not connected to WiFi directly, reading from buffer (bytes 0 - 32000, expecting to read ~42666 bytes…
[SER] Reading 23% complete…
[SER] Reading 50% complete…
[SER] Reading 76% complete…
[SER] Reading 89% complete…
[SER] File is 28744 bytes after decoding
[SER] Failed to upload to https://ingestion.edgeimpulse.com/api/training/data StatusCodeError: 400 - “Invalid message body, was specified to be CBOR but could not decode message (Undeterminated nesting)”
statusCode: 400,
error: ‘Invalid message body, was specified to be CBOR but could not decode message (Undeterminated nesting)’,
options: {
headers: {
body: <Buffer 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 … 28694 more bytes>,
